Power steering throttle assist
Old Apr 5, 2010 | 09:44 AM
blacklab1's Avatar
blacklab1
I swapped a 5.0 mustang engine into my 91 f-250, when pulling the old engine I found a plastic connector unplugged down be the power steering box.
When I installed the new engine I plugged the plug back in. My engine run great , but was idling up and down. It would idle down enough to stall.
I unplugged the sensor and the idle settled down.
What is the unit on the hose called and is it really necessary?
Old Apr 5, 2010 | 09:52 AM
Conanski's Avatar
Conanski
If the sensor was on one of the power steering lines it would be the power steering pressure switch, and no it's not really necesary.
Old Apr 5, 2010 | 02:15 PM
blacklab1's Avatar
blacklab1
Thanks for the info. Is there anywhere that shows what all the sensors, switches , relays,
valves etc. that are on or around these engines, what they're called and what they do?
I see a lot of threads referring to ABC valves or DEF sensors, I'm lost.
Old Apr 5, 2010 | 02:38 PM
Lazy K's Avatar
Lazy K
Ford Fuel Injection This is a good site for all the EFI stuff.
Old Apr 5, 2010 | 03:04 PM
LCAM-01XA's Avatar
LCAM-01XA
There is a power steering pressure switch? What does it do? And is it just a gasser thing, as my '90 diesel has nothing like that...
Old Apr 5, 2010 | 03:39 PM
Conanski's Avatar
Conanski
I'm not sure if it's simply a low fluid sensor or if it signals an increase in pressure when the wheel is turned so the EEC can increase rpm to compensate for the extra load. I suspect the latter but whatever the reason it's not something that is consistent on all trucks or years, I have seen some with it and some without. Yet another Ford mystery.
Old Apr 5, 2010 | 04:20 PM
BucksTrucks's Avatar
BucksTrucks
Its just on the 5.0s
Old Apr 5, 2010 | 06:14 PM
LCAM-01XA's Avatar
LCAM-01XA
Must be a truck thing, as 5.0 cars don't have that... must be cause of the extra load on the front wheels when the truck is full to capacity.
Old Apr 5, 2010 | 09:23 PM
SaikotikGunman's Avatar
SaikotikGunman
I couldn't find one on my '95...
Old Apr 5, 2010 | 09:40 PM
Elderstarr's Avatar
Elderstarr
Common culprit is the Idle Air Control.
http://www.moddedmustangs.com/cleaning-your-iac.html
Old Apr 5, 2010 | 10:32 PM
HrdDrv's Avatar
HrdDrv
My '62 Fairlane had that. Turn the wheel lock-to-lock, and the idle would step up. Kept the 289 from stallin' when turning hard right/left. Pain in the a$$ when it was in gear...
