Steering coupling?
Old Apr 4, 2010 | 10:39 PM
714x4custom's Avatar
714x4custom
Steering coupling?
Anyone know where I could pick up a new steering coupling, where it connects to the steering gear for a 71 f100 4x4? Or will I have to replace the whole steering shaft? Ill include a pic so you know what im talking about
Old Apr 4, 2010 | 11:08 PM
GreenDinosaur's Avatar
GreenDinosaur
Steering Shafts - WILD HORSES Early Ford Bronco Parts
I found these this morning, hope this helps
Old Apr 4, 2010 | 11:34 PM
714x4custom
Perfect, Thanks bud!
Iv been looking for a while, all I could find was rag joint!
Old Apr 5, 2010 | 12:07 AM
GreenDinosaur
Anytime man, I have found looking for the 4x4 specific parts to be a hassle at times, turns out that the f100 models share alot of parts that were used on broncos.
Old Apr 5, 2010 | 03:42 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
It's not perfect, because this part is not the same as a Bronco!
This part may look to be the same as the one used on a Bronco...but it is not the same as the one used on a Bronco.
This is: D5TZ3B676B (replaced D2TZ3B676B, D1TZ3B676A & C7TZ3B676C), the lower section of the F100 4WD's shaft and coupler assembly.
Fits 1967/75 F100 4WD only!
For a Bronco of this vintage, this part is: D2TZ3524A (replaced C7TZ3524E) Steering Shaft & Flange Assy-60" long! Fits: 1967/72 & 1973 Bronco w/manual steering before serial number S20,001.
btw: The steering shaft and coupler for a 1967/75 F250 4WD looks the same as the F100 4WD & Bronco, but it's F250 4WD only.
Old Apr 5, 2010 | 07:34 PM
714x4custom
Wow thanks man, Very helpful! i was just about to order that, good thing you chimed in!
Thanks alott!
Do you where abouts I can get one, I have tried numerous online ford part stores and cant find it using that part #?
Old Apr 5, 2010 | 08:07 PM
NumberDummy
Thanks alott!
The part you pictured in post #1 was not sold by itself. It only came with the complete shaft & coupler assy, or with the lower shaft and coupler.
The U-joint and other misc parts that make up the complete assembly (there are 21 total parts!) were also available separately.
The 4WD shaft & couplers used in 1976/79 are not the same, as these are a one piece assembly. Will not fit 1967/75.
D5TZ3B676B (replaced D2TZ3B676B, D1TZ3B676A & C7TZ3B676C) .. Lower Shaft & Coupler / All are obsolete.
D5TZ3B676B = GREEN SALES CO. in Cincinnati OH has ONE = 800-543-4959.
No Ford Dealer, no other obsolete parts vendor has any.
D1TZ3B676A = GREEN SALES CO. has ONE.
No Ford Dealer or obsolete parts vendor has D2TZ3B676B or C7TZ3B676C.
FTE has a (WA) Ford Dealer Parts Dept sponsor: PARTSGUYED.COM that gives members a parts discount off the actual FoMoCo MSRP.
Parts Guy Ed is Ed Olson, the parts manager of Horizon Ford (Tukwila) & Millennium Ford (Burien).
Since Ed and I have the same parts locator sources, he won't be able to help you locate this part...but could help you locate other stuff (if I'm not around).
Old Apr 7, 2010 | 02:01 PM
GreenDinosaur
Hey number dummy, not to hijack or anything or doubt yer vast knowledge, but the part pictured above on my truck which is a 70 f100 4x4 is mounted to my steering box, and the steering box that is currently in my truck came from a 69 bronco, i'd say it shared the same part, but maybe i'm missing something?
The factory steering shaft on my truck has a u-joint attached at the end of the column, the shaft goes into this coupler at the steering box. if you look at the link i posted, mine looks just like the picture they have for the 65-75 manual steering. I have been searching the best I can throughout the net for 4x4 related parts and always get sent to bronco sites. Took me a lil while to figure out I have Dana 30 style steering knuckles that use king pins instead of the later ball joint style. Heck, even the spindles I installed last weekend were listed for 72 bronco, and they were the exact same thing as what came off. If the coupler comes apart as the gentleman above clearly shows in his picture, why would a person need to buy the whole shaft and coupler? Since we are on this subject could you possibly let me know if someone sells the u-joint that goes at the other end? I think the needle bearings are shot. I don't mean to be a pain, just learning like the rest. Your knowledge and help is always appreciated.
Old Apr 7, 2010 | 08:19 PM
714x4custom
I just picked one up at the wrecking yard for 20 bucks, shaft and coupling as they would not sell the coupling alone! But I agree dinosaur I havent found just a coupling for it, Evey where you have to buy the shaft too! Unless you have rag joint!
Old Apr 8, 2010 | 02:33 AM
NumberDummy
Because, this is how FoMoCo operates, you had to buy the whole tamale.
Ford did not sell just this part by itself, it was only sold with the steering shaft & flange (Bronco) or the lower shaft & coupling (F100 4WD).
If you look in the parts catalog illustrations (1965/72 or 1973/79 passenger car for Bronco), 1964/72 or 1973/79 truck parts catalogs for F100 4WD's, you will see there in no part number shown for it.
Ditto for 1967/75 F250 4WD's. How can I list the part number for this part...when there isn't one?
C6TZ3815B (replaced: C3TZ3815A) .. Joint Kit-Steering Column Coupling Shaft Slip Yoke / Obsolete
Fits: 1963/69 N500/750 // 1963/79 C500/1000 // 1966 F100 4WD // 1967/75 F100/250 4WD // 1970/79 LN500/900.
C6TZ3815B =
BOB ALLEN FORD in Overland Park KS has ONE = 800-676-0675. This dealer wants mega-bucks for obsolete parts!
No other Ford Dealer, no obsolete parts vendor has any.
C3TZ3815A =
BOB ALLEN FORD has ONE.
MILLER OBSOLETE PARTS in Binghamton NY has ONE = 800-546-7278.
COLLECTORS AUTO SUPPLY in Oroville WA has ONE = 800-414-4462.
GREEN SALES CO. in Cincinnati OH has THREE = 800-543-4959.
No other Ford Dealer or obsolete parts vendor has any.
But wait...there's more!
Considering all the applications this joint kit fits, you can prolly buy it at NAPA, other parts stores.
There is a Timken part number (that autoparts stores use) for this joint kit: CPL6S-22
Old Apr 8, 2010 | 06:16 AM
GreenDinosaur
Hey great, glad you found what you needed. I'm not quite as fortunate in my neck of the woods, most of these trucks were recently scrapped.
Old Apr 8, 2010 | 06:22 AM
GreenDinosaur
Darn it number dummy your magic keyboard has outdone mine. I tried looking up those part numbers and drew blanks, even got blank stares from the parts store when I went there looking. I swear, anymore you gotta have your own books and part numbers in hand before you go to the store. I will look into these.
Old Apr 8, 2010 | 06:59 AM
NumberDummy
The 1964/72 Ford Truck Parts Catalog is available on a CD from hipoparts.com for about 22 bucks.
This catalog has 4849 pages of text, 1961 pages of illustrations. Since every part is illustrated, the catalog can also be used as an assembly/dis-assembly manual.
If you get the catalog (or already have it), look here: Illustration Section 35, page 9. This is the exploded view of all the parts in the 1967/72 F100/250 4WD's steering column and steering gearbox.
See if you can find the number for that part the OP was a lookin' for. Lotsa luck, cuz there ain't one!
This catalog also includes the following cross reference info (at the end of the text section):
Manufacturer's part numbers to Ford part numbers (pages 1 thru 98) & Ford part numbers to Manufacturer's part numbers (pages 99 thru 188).
This is where I got the Timken part number for that joint kit.
Old Apr 11, 2010 | 01:47 AM
714x4custom
Sweet, Im going to order that cd! Thanks Bud!
Old Oct 24, 2017 | 05:42 PM
moredleg's Avatar
moredleg
4wd Low
Hello, I would like to know how to get the pin out of shaft to replace the steering the steering coupling boot. 67 ford f250 4x4
