combo
Old 01-27-2003, 10:02 AM
TrackStar's Avatar
TrackStar
TrackStar is offline
combo
I've got a late block but am hoping to aquire a set of early heads. Along with intake, carb, and headers, what size cam should i go with. I'm basing my idea off the Edelbrock Power Package(469hp). Can I get 500hp out of my setup? If not what more would I have to do?
Thanks,
Andy
Old 01-27-2003, 10:19 AM
georgedavila's Avatar
georgedavila
georgedavila is offline
combo
Wasn't the Edelbrock Power Package rated with aluminum heads?
Old 01-27-2003, 05:42 PM
TrackStar's Avatar
TrackStar
combo
yes. so can you acheive the same flow numbers with a set of DoVE heads that have been worked?
Old 01-28-2003, 09:09 AM
georgedavila
combo
Fully ported DOVEs will flow about the same as out of the box edelbrock heads.
Old 01-28-2003, 04:24 PM
TrackStar's Avatar
TrackStar
combo
I checked out your build sheet on the 500hp 460. are those actual power numbers or estimated?
Andrew
Old 01-29-2003, 09:24 AM
georgedavila
combo
An old estimate before going to edelbrock heads and crankcase evac system. Somebody ran it for me on one of the pro simulation software packages and said 550hp. It's in the truck and I hope to fire it in the next week or so and then I'll have it chassis dyno'd. I'm after 400hp at the rear wheels.
Old 01-29-2003, 10:08 AM
TrackStar's Avatar
TrackStar
combo
I'd be anxious to see what you come up with. Keep us posted of your results. If you do in fact make 400 at the wheels, I'll probably base my build off of your setup.
Andrew
AMEC Electric LLC
6.7L Power Stroke Diesel
24
02-08-2012 09:47 PM
AMEC Electric LLC
06-28-2011 05:50 PM
08screwfx4
2004 - 2008 F150
17
09-22-2008 07:05 PM
351slug
12-31-2006 09:23 AM
Andy_Bracy
07-12-2006 12:20 AM
Quick Reply: combo
