steering issues 05 Expy
Old Apr 4, 2010 | 08:04 PM
bbdano's Avatar
bbdano
My 05 Expy with 96 K miles recently developed steering problems. While turning using hand over hand method, every other motion of the hand is really hard, followed by easy then hard again. Will not return upon completing turn. Didn't always act like that, worked its way up from approx two weeks ago. Had the system flushed at local ford dealer. They used Pro Tec system. Didn't seem to help, thought I'd try it rather than replace rack, pump or gearbox (does it have a gear box if it has a rack)? The symptoms would actually come and go over the period of this past week. Now it seem like it here to stay and possibley get the to point that it will be totally difficult to steer.
A mechanic told me a couple things to try, first check circulation of fluid while vehicle is running and turn wheels side to side. Fluid seems to be flowing fine. He also said to check a screen on the pressure side of the line going in to the pump. Some times they will plug up and give you problems. He also said something about a check valve. Gonna need a diagram of the pump for that one.
If anyone has any information on this subject, would really appreciate it,
thanks,
dano (bbdano)
Old Apr 5, 2010 | 12:04 PM
alwaysfords41's Avatar
alwaysfords41
Can't help you with the issue, but can tell you that you stand a much better chance of getting your answer here as opposed to your post at Edmunds.
Old Apr 5, 2010 | 01:08 PM
alloro's Avatar
alloro
Would you say it's every 1/2 turn of the steering wheel? If so, you could be looking at a bent sheering shaft, which is kind of unlikely, or you could more likely be having a binding issue with the steering shaft coupler.
Old Apr 5, 2010 | 08:11 PM
bbdano's Avatar
bbdano
steering
I stopped by a local garage, specializing in front end alignments. He took a look at it and thought maybe the intermediate shaft may be seizing up. Which kinda makes sense. Yes, it is about every half turn. The shaft does not appear to be bent, that was another thing he looked at. I suppose I'll have to tear that off. I hope its as easy as it looks...and it would be less messier than checking the screen on the pressure line to the pump.
thanks,
dano
Old May 13, 2010 | 12:22 PM
davesexpedition2005's Avatar
davesexpedition2005
I have been having a problem with mine that sounds like this. Any luck with a fix?
Old May 13, 2010 | 05:09 PM
bbdano's Avatar
bbdano
JUst posted one, but to the point...try spraying the intermediate shaft with WD40 while someone is turn the steering wheel from stop to stop. Just be careful because you do this with the engine running.
Good luck
dano
Old Aug 15, 2010 | 03:41 PM
davesexpedition2005
steering problem fixed
Thanks to all for the ideas. "WD-40" and "BP blaster" worked for a short time. I soaked the U joints above and below the intermediate steering shaft with "brake free" and have not had a problem since.
Old Aug 24, 2010 | 05:22 PM
bbdano's Avatar
bbdano
You're welcome, I've still had bouts with mine, but have yet to get serious on it with the liquid wrench or any of that stuff...got other things to do to it, like replace spark plugs. It just turned over 100K not long ago. Right after it turned over the darn fuel pump driver module went bad...like over night! So that took a decent chunk out of my bank account. Easy fix though.
dano
Old Aug 25, 2010 | 09:30 PM
davesexpedition2005
Yeah, the fuel pump driver module.......dealer got $500 out of me on that one! Now that I know where it is, it's no wonder it shorted out.
Old Aug 26, 2010 | 09:34 AM
bbdano's Avatar
bbdano
YIKES! They'll get ya comin and goin. The Honda people wanted my arm and both my wife's legs to fix our little p.o.s. civic. Done it myself for free, and it kept me out of the house for a couple days too!
bbdano
Apr 15, 2013 01:27 PM
dixie460
Jan 23, 2013 03:38 PM
bbdano
Jan 28, 2011 04:39 PM
trx350first
2004 - 2008 F150
Mar 10, 2010 06:56 PM
98xlt4x4
1983 - 2012 Ranger & B-Series
Jul 9, 2004 02:01 AM
