Ok, more problems.
Old Apr 3, 2010 | 06:08 PM
Explorer Freak's Avatar
Explorer Freak
Ok, more problems.
Hi,
Today when I went to start my truck, it ran fine, until I put it in drive. It died. I started it up again. This time it ran fine all the way out on the highway. It drove as good as it ever does, until I got to the intersection I was turning at. After I got on this road, I could smell a really strong exhaust smell. I didn't think much about it. Soon, it started sputtering, and loosing power. I stepped on the gas, and that didn't seem to help.
It kept getting worse and worse. Finally, it died and I had to coast to the side of the road. I tried to re-start it, but all it would do is turn over, slowly. I checked to see if it had thrown a belt or something, but everything was as it was before. Any ideas as to what is causing this?
Old Apr 3, 2010 | 09:10 PM
Explorer Freak
Nobody has any ideas? Has anyone else had something like this happen?
Old Apr 3, 2010 | 10:06 PM
bigred86fordf250's Avatar
bigred86fordf250
Possibly a fuel problem. I assume the temperature was normal and it was not overheating.
It's hard to say from the description I think it could be a very wide range of things.
Old Apr 3, 2010 | 11:05 PM
Explorer Freak
Yah,
The temp was normal, and it wasn't overheating. It just sputtered, and kept loosing power. I put the pedal to the floor and nothing happened.
I just replaced the fuel pump, the fuel filter looked brand new, so I didn't replace it (maybe I should anyway).
One thing I was wondering about was vapor lock. Is that a possible cause? But also why won't it restart? After I got it towed, it did start for a second (literaly), but then it died.
I need to get the truck running again so I can get it back to my place to start restoring it.
Any suggestions would be appreciated.
Old Apr 4, 2010 | 01:22 AM
fepowerguy8's Avatar
fepowerguy8
Well if starts slowly it could be a starter solonoid or a coil. I'm leaning towards the solonoid though, just had a similar issue on my truck.
Old Apr 4, 2010 | 06:26 AM
texaskid22's Avatar
texaskid22
Get a spark testor, they are cheap and easy to use. Next get a can of carb cleaner. These are the most basic shade tree mechanic tools that every old truck owner should have hidden away. You can give a boost of fuel down the carb with the spray, if it doesn't start you know its likely to be lack of spark. You can then pull a wire and connect the spark tester. (I usually use the 5-8 cyl with my hand threw the wing window to crank). If you have a jumper wire for the starter solenoid 1-4 will be best of course.
Try these two quick tricks and let us know of the outcome.
(I'm a amazon-o-holic)
This is the spark tester I like, although I have several different types (the shorter type will only work well with the coil wire, may not reach the connector in the spark plug wires)
Amazon.com: Mountain 8709 In Line Spark Tester: Automotive
This is handy for bumping the engine over in a professional manner.
Amazon.com: Actron CP7853 Remote Starter Switch: Automotive
Old Apr 4, 2010 | 06:50 AM
Rogue_Wulff's Avatar
Rogue_Wulff
You need to check for fuel and spark. One or the other is likely the cause.
Old Apr 4, 2010 | 09:15 AM
ctubutis's Avatar
ctubutis
This sounds like a fuel delivery problem (likely running on vapors for that one second
there). Test the fuel pump's output pressure and flow rate.
Old Apr 4, 2010 | 10:03 AM
fepowerguy8
good point guys, just because a part is new does not mean it works right.
Old Apr 4, 2010 | 09:03 PM
Explorer Freak
Thanks! I appreciate all the input. I will get a spark tester tomorrow. I hope it is just a fuel delivery problem. On these old trucks, there isn't much to the fuel system.
The one thing that still confuses me is, why would it just all of a sudden loose power? If it had a fuel or spark problem, it wouldn't just happen all of a sudden, unless the fuel filter is clogged.
Also, could this have happened because I increased the idle speed too much?
Yet another thing: I know this may sound stupid, but could I have run out of gas? When I bought the truck, I put about 10-12 gallons in the front tank. I have driven it about 40 miles on that fuel. What fuel economy would my truck be getting? Is is possible to use up 10-12 gallons in 40 miles?
Thanks (again)!
Old Apr 4, 2010 | 09:21 PM
ctubutis's Avatar
ctubutis
Harbor Freight has similar spark testers....
Old Apr 4, 2010 | 09:30 PM
ctubutis's Avatar
ctubutis
40 miles/10 gallons = 4MPG; pretty bad but not unheard of.
Maybe I missed it but I don't recall seeing the specifics of your truck? Year/engine
tranny/etc. I don't display any sigs nor avatars 9if your specifics are in there somewhere).
Do you have an electric fuel pump? They can burn out and stop working pretty
instantaneously.
Old Apr 4, 2010 | 10:57 PM
Explorer Freak
No, I don't have an electric fuel pump.
My truck is a 1981 F100 with a 302, C6, and 9" rearend. It is bone stock with no mods yet.
I just need it to limp home, just 11 miles and then I can work on it.
Old Apr 5, 2010 | 11:28 AM
texaskid22's Avatar
texaskid22
I'm thinking its a ignition problem but it really can be a lot of things including running out of gas. Don't forget about all of the idling done while tweaking the engine.
Old Apr 5, 2010 | 11:44 AM
Rogue_Wulff
Lift off the top of the air cleaner, look down into carb, and operate the throttle linkage. If you don't see 2 sprays of fuel while opening the throotle, you're not getting fuel to the carb. This could be from a bad fuel pump, plugged fuel filter, or simply no gas left in the tank. Get some fuel, add most to the tank, and dribble a little into the carb. See if it will start, or at least try to start. You may need to repeat the fuel dribble a couple times before the pump can start supplying the carb with fuel, if it simply ran out of fuel.
If you see the fuel spray, check for spark.
The 2 most common causes of the condition you described is not getting fuel, or not getting spark.
If it's getting fuel and spark, there could be another issue. But let's save that for after you've checked those 2 items.
