Sponsored by: Real Truck
5.4 oil problem
Old Apr 3, 2010 | 05:07 PM
colton_c_r's Avatar
colton_c_r
5.4 oil problem
I have a 200 f-250, 5 speed with a 5.4l. I took the heads off due to a miss. I put a new valve, spark plugs and inserts in it. The work was done by a professional. It's all back together. The whole top end is new. It has a new intake. During idle, it will miss all way until about 2200 RPM, but runs great. At the point the miss starts, it will start smoking blue. I towed another truck approximately 400 to 500 miles and have burnt 5 quarts of oil. Can someone tell me how to fix the miss and burning of oil?
Old Apr 3, 2010 | 05:23 PM
gearloose1's Avatar
gearloose1
Absent codes and a electronic problem, do a power balance test to isolate the cylinder.
Blue smoke says rings / valves at that cylinder.
Are you sure it is not cheaper to just toss in a reman long block?
