Warn locking hubs
Old Apr 2, 2010 | 08:16 PM
MMSGuthrie110's Avatar
MMSGuthrie110
Warn locking hubs
96 F150 dana 44 TIB front axle. when i put on my Warn locking hubs the c clip that clips onto the axle would not go on because the hub would not slide back far enough. this happened on both sides. i am using the lockuts that came with my mile marker kit if that makes a difference. I have the main clip on that slides arou the hub. Just wondering if this would hurt anything to not have this clip on.
Old Apr 2, 2010 | 09:00 PM
danr1's Avatar
danr1
Reach behind the steering knuckle and pull the stub shaft all the way out then install the clip. May need to use a bar to aid in compressing the spindle seals, just don't over do it.
