Throttle Position Sensor Testing
Is there a way to test the TPS without the prescribed "breakout box" ?
There must be a way to check resistance or voltage variations while operating the throttle. Reference voltage stays right at 5v.It doesn't start up easily and I get random and inconsistent codes, the latest one is 63. I am still thinking it may be the computer, but no one stocks matching part numbers (someone previously posted that it came out of a Bronco not a pickup)
I dont know if this is what you needed but thats how I would base checking it....
the wire from the TPS to the computer should be 0.90 volts at closed throttle and about 4.5 volts at WOT.
You check it by back probing the plug that goes to it.
The (-) from your analog meter goes to the SIG wire in the same plug. The other wire is 5 VDC. You can not use a DVM for this check only an analog VOM.
For more information go to this link:
Ford Fuel Injection Throttle Position Sensor (TPS)
However, thanks for the link! Lots of good info there.
Adjusting the idle screw is something I never would have thought of. The kid who had this truck likely messed with the idle screw on the throttle body as it appears to be mangled on one end.
When using a DVM you can only check the TPS at each end of the scale and not where the TPS is setting on its sweep most of the time as you drive and where it wares the most.
To use the analog VOM you hook it up and move the throttle real slowly from closed throttle to WOT and then slowly let the throttle close. The needle should move very smooth across the scale from 0.90 volts to about 4.5 volts with no jerks or dead places.
DVM are very good in places but this is not one of them. It is good for checking the 5 VOLT supply and the voltage at each end of the sweep of TPS.
Maybe now you can go back and teach the instructor at the tech school how to do it. But they may not have any VOM still around to use at the school in this way.
I only got a flat 1V while operating the throttle. Reference voltage was good at 5V, so it seems the TPS is faulty.
Thanks everyone for the info.
