P0401...Need help fast
Old Apr 1, 2010 | 01:16 PM
devildog30188's Avatar
devildog30188
So I really hate this P0401 code, just popped up on me again after I just replaced the DPFE sensor and time is running short until my emissions have to be done. I picked up a EGR valve mounting gasket today so next step will be to clean out the EGR valve as much as I can. I need help, any ideas of wat else could have caused this code to pop up?
Old Apr 3, 2010 | 01:29 AM
devildog30188
Come on guys, I know somebody has gotta have some sort of idea about this, any and all help would be appreciated, but I gotta get this figured out.
Old Apr 3, 2010 | 07:44 AM
pawpaw's Avatar
pawpaw
I'm not clear on your P0401 code repair.
I know you said you have a beat on 98 4banger & from your DPFE thread that you did some research on your P0401 code & ordered the less expensive DPFE sensor from RockAuto.
Did replacing the DPFE sensor fix the problem for a while, but it returned????
Or did you just replace the DPFE on a researched hunch, without doing any EGR system testing, erased the code & hoped for results????
You could have more than one problem, so you need to visit the Tech Info thread as as been suggested & do some EGR system component trouble shooting, to determine which component/s are acting out & replace the faulty one/s.
You could have a vacuum leak to the system, a bad vacuum switching valve diaphragm, that controls vacuum switching to the EGR valve, dryrotted/leaking vacuum lines to either, if the engine is burning oil, or has had the wrong srevice grade oil used, or a clogged up PCV valve thats caused oil comsumpton, the system may be clogged up with carbon & needs cleaning, or maybe the new aftrmarket DPFE sensor is acting out.
Unless the EGR valve is rusted up & falling apart, they rarely go bad.
The P0401 suspect list usually goes about like this, DPFE sensor, leaking/dryrotted rubber vacuum lines, faulty/leaking vacuum switching valve diaphragm, carboned up system, faulty/leaking EGR valve diaphragm, bad/rusted out EGR valve, faulty EGR valve.
Anyway do the Tech Info thread EGR system tests & component testing/trouble shooting & let us know how it goes.
Michael Ward
1997 - 2003 F150
Jun 11, 2014 09:58 PM
Khrazkix
Nov 5, 2013 05:58 PM
kevinjrgaston
2004 - 2008 F150
Oct 26, 2013 04:22 PM
Johnnyblaze
Aug 29, 2013 07:06 PM
propellerhead
Jun 14, 2013 08:14 PM
