What does your temp gage read!
Old Mar 31, 2010 | 02:03 PM
idahodisco's Avatar
idahodisco
I think my temp gage is off but not sure?
It will travel back and forth from the first mark to the N on Normal But on the way home it stayed at the N for about 30 min all down hill so I am thinking it should be at the N always??
So what does yours do??
Old Mar 31, 2010 | 11:14 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Mine says 195 degrees unless I am pulling hard.
Then it reads somewhere between 195 and 240 depending on how big the hills and load are.
What all that boils down to is, if you want to know how hot the engine is, get a real gauge.
N don't mean much.
Old Apr 1, 2010 | 12:23 AM
idahodisco's Avatar
idahodisco
How hard is it to install and do I have to unhook the dash temp guage?
Old Apr 1, 2010 | 12:36 AM
starmilt's Avatar
starmilt
I would install it where the overheat light sensor goes instead of the guage sensor. Once you have a real guage, you will find yourself looking at instead though.
Old Apr 1, 2010 | 09:19 AM
iverger's Avatar
iverger
I haven't gotten around to installing aftermarket gauges yet. But my factory gauge was acting exactly the same way and I had 2 issues. First the connector behind the alternator was loose and a gentle pinch with a pair of pliers stopped most of the erratic behaviour. Then last weekend I replace the thermostat (from ford of course) and now it consistently sits between the "o" and the "r".
But like mentioned above, real gauges make a lot more sense.
Bob
Old Apr 1, 2010 | 10:22 AM
idahodisco's Avatar
idahodisco
So the does the new temp sensor replace the the old temp senson behind the alternator???? Just unscrew the old and screw in the new?
Old Apr 1, 2010 | 06:43 PM
drewdole's Avatar
drewdole
we put a sun pro in my f250 93, as old temp gauge was also erratic. oil press. sending unit should be at center of engine next to fire wall , behind air filter assemb. to a seperate gauge. my temp stays in the 190 to 195 range
Old Apr 1, 2010 | 06:49 PM
rodneywar's Avatar
rodneywar
Mine is about the same for the first part i had problems with the sensor being erratic as well but pliers took care of that!!
Old Apr 1, 2010 | 11:36 PM
starmilt's Avatar
starmilt
Courtesy of a guy that always hung out here before he bought a stroke. lol
Old Apr 2, 2010 | 12:24 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
lol!
yeah that trader.
that things to pretty for work anyway.....unless.......ya got a flatbed dump on that new rig yet Dave? hehe
Old Apr 2, 2010 | 04:12 PM
idahodisco's Avatar
idahodisco
Well I installed the temp gauge it took 20 min and $24 bucks I put it on the temp light switch! Works great
Old Apr 2, 2010 | 07:35 PM
WarOzz's Avatar
WarOzz
Your so much better off then relying on the stock gauge.
Old Apr 2, 2010 | 09:37 PM
IDIDieselJohn's Avatar
IDIDieselJohn
My 7.3 gauge reads just under the N fully warmed up, and goes down abit, then slowlly comes back up, then goes down again. Does this all the time, when the t-stat opens.
Old Apr 3, 2010 | 12:05 AM
idahodisco's Avatar
idahodisco
Thats what I thought mine was doing but now that I have a gauge it just sits at 180 and my other gauge goes up and down! Stock gauges are junk!
Old Apr 3, 2010 | 09:00 AM
Dave Sponaugle
I still spend more time here than I do in the Stroke forum, I have just been rather busy outside after the winter we had.
Yesterday my son and I were out looking at an 87 F350 4x4 IDI for his first 4 wheeled vehicle.
I think the driving his motorcycle in the rain and cold weather is getting old.
