Electric Fan Controls
Old Mar 31, 2010 | 01:52 PM
Moto Mel's Avatar
Moto Mel
I know this topic has been covered several times but I cannot find the info I need right now.
I'm replacing the engine in my Navigator as well as the radiator and while I'm at it I'm replacing the clutch fan with a dual fan from a Continental V8 fwd car. I'm trying to do a neat install by wiring the fans to the AC compressor and using a temp. probe into the radiator with a relay and direct wiring it to the battery for power.
I cannot find the info on the Temp. probe that I have read about on this board. Unfortunately the search function hasen't helped.
If anyone has the info I neeed I would appreciate it. suggestions would also be appreciated.
Thanks
Old Mar 31, 2010 | 02:03 PM
alloro's Avatar
alloro
Specifically what info are you looking for?
Old Mar 31, 2010 | 02:14 PM
Moto Mel's Avatar
Moto Mel
The temp sensor that is inserted in the radiator fins and any suggestions or links to other's installs.
Old Mar 31, 2010 | 06:13 PM
alloro's Avatar
alloro
I didn't find anything about the sensor, but I did find this page showing how to do the fan install.
Mark VIII Fan Install
Old Mar 31, 2010 | 08:48 PM
Moto Mel's Avatar
Moto Mel
That is a good bit of information but at this time I think I only need the Temp. Sensor's brand name and p/n or where I can buy it. Thanks
Old Apr 1, 2010 | 07:47 AM
c_hohensee's Avatar
c_hohensee
I believe that Flexolite sells parts for their set up, althought you you may have to buy the whole controller and not just the temp probe. If you did it should work with the fans you want to use.
Old Apr 1, 2010 | 08:06 AM
Moto Mel's Avatar
Moto Mel
I am looking for just the temp probe and thought that Flexolite would only sell the probe in their kit so I didn't check. I will now though, Thanks
thatoneguy_10
WTB - Parts & other
May 11, 2016 12:13 PM
Wagion
Nov 20, 2015 06:26 PM
F-250 restorer
May 1, 2015 01:55 PM
tekrsq
Jan 29, 2012 12:04 PM
hooler1
Oct 23, 2011 10:11 PM
