Smokes bad when cold
Old Mar 31, 2010 | 11:09 AM
wrbowcal's Avatar
wrbowcal
My truck runs fine and I have had little trouble with it other than those darn cam positioning sensors.My truck smokes really bad when it is cold untill it warms up (white blueish smoke)and its hard on fuel.It has 250000km on it and has good power.Im thinking it could be injectors.
1997 7.3L
Old Mar 31, 2010 | 11:14 AM
Copedawg's Avatar
Copedawg
WELCOME TO FTE!!!
How cold is cold? What are the outside temperatures? Have you tried to pulg it in overnight to see if you have the same results?
Again WELCOME!
Old Mar 31, 2010 | 11:45 AM
Talyn's Avatar
Talyn
its a 97 cope dog, doesn't have block heater stock, it was an add on that year.
but yea, if you have it. plug it overnight and see if it makes a difference.
blueish smoke on startup sounds like bad injector o-rings though.
Old Mar 31, 2010 | 11:57 AM
Copedawg's Avatar
Copedawg
I spose I am was trying to weed out if it is a cold weather issue. I also believe you will get that if you have low or very old oil. But if it is oil it may run like buttox for a bit.
How long does the smoke last after getting it started?
Old Mar 31, 2010 | 12:07 PM
JamesHajek's Avatar
JamesHajek
I have bluish white smoke on start up as well and im pretty sure its injector orings. Does it clear up fairly fast or does it take a while? Mine clears up in a matter of seconds.
Old Mar 31, 2010 | 02:50 PM
wrbowcal's Avatar
wrbowcal
Originally Posted by Copedawg
WELCOME TO FTE!!!
Again WELCOME!
When I plug it in its not as bad,It smokes no matter what temp is out side until it warms up.
Old Mar 31, 2010 | 02:54 PM
wrbowcal's Avatar
wrbowcal
No it takes awhile,in the winter it could take 30min to clear it up.I read a post here that it could be the glow plugs.Someone told me they still heat after the engine is running intermeadately.I dont know if this is true.
Old Mar 31, 2010 | 03:07 PM
Copedawg's Avatar
Copedawg
30 minutes? WOW! When was the last time your oil was changed? New/fresh oil makes a BIG difference.
wrbowcal's Avatar
wrbowcal
Mines got the block heater and works good but sometimes I dont have access to power and when I start up its a smoke show.This truck starts good in the cold the plugs stay on for about 8-10 secs and it fires.Thanks it could be the injector o rings.Im worried that the piston rings are going I dont want that problem.
Old Mar 31, 2010 | 03:08 PM
JamesHajek's Avatar
JamesHajek
yes, they are on for up to 120 seconds i think depending on oil temp. The WTS light is just a dummy light. The glow plugs stay on after the engine is started to help reduce smoke. So your glow plugs could be bad but then you would be having a really hard time starting it in the cold. 30 min is an extremely long time for it to keep smoking blue.
Old Mar 31, 2010 | 03:09 PM
wrbowcal's Avatar
wrbowcal
5 mths ago.switch to semi synthetic
Old Mar 31, 2010 | 03:10 PM
Copedawg's Avatar
Copedawg
I'm not trying to be a smartazz but have you changed the oil in the last 5 months?
Old Mar 31, 2010 | 03:15 PM
Big Ruth's Avatar
Big Ruth
My 95 smokes like a train when cold. The day after I got it, on a 12 degree morning, the EX Arizona truck was mighty pissed. She started but smoked something crazy.
Figured out she has a block heater and when I plug it in there is ZERO smoke.
In short, yes, will smoke when cold.
Old Mar 31, 2010 | 03:22 PM
JamesHajek's Avatar
JamesHajek
Agreed, But not for 30 minutes.
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
Old Mar 31, 2010 | 03:24 PM
Big Ruth's Avatar
Big Ruth
Thats true. Probably shouldn't for 30 mins. Although if its idiling I can see it smoking for a while since they don't get warm all that quickly under idle.
