Steering Play Issue
Old Mar 30, 2010 | 09:43 PM
TX Silver's Avatar
TX Silver
Steering Play Issue
I've searched and seen the multitude of fixes for the wandering, but I know exactly when this started happening and was wondering if anyone might know why in relation to my project.
I bought the X with about a 4" lift and P315 tires. I have lowered back down and switched the components back to "stock" specs. When I lowered it I noticed no difference in the handling. I then switched the P315s to P285s and started to notice a wandering or loose feeling. Having the front end realigned made no difference.
I've played with tire pressures and it feels a bit better, but the wife is still uncomfortable driving it.
Looks like I'm about to start replacing front end parts - what should I start with?
Thanks,
TX
Old Mar 31, 2010 | 06:01 PM
03-6L-X's Avatar
03-6L-X
Are the tires "D" or "E" rated?
What pressure are you running?
Might want to explain "stock" specs.
Old Mar 31, 2010 | 07:52 PM
TucsonTripleB's Avatar
TucsonTripleB
As Mike asks above, the load rating can be a factor. Also, as tires get more narrow they are more susceptible to "following" groves/patterns in the road. Finally, just the type/style of tread pattern of the tire can drastically impact wonder. (ie tires with sharp inner and outer edges on their tread tend to catch grooves a lot more then rounded edges)
I know this is not much help, just sharing my experiance with thing I have found that can cause what you discribed.
Old Apr 1, 2010 | 06:48 AM
Forest's Avatar
Forest
I'm going through this same internal debate with myself--the 2nd time around. I managed to "fix" my 2003, but I admittedly did some wholesale parts replacements before getting it under control. That means I don't know exactly what the fix was.
Rather than being totally logical, you might consider replacing the drag link, then tie rod ends, then tighten up the steering gear. These parts are easy to replace and for maybe <$300 you may get this under control. If they don't work, then the next logical replacements would be the ball joints and then the track bar.
Old Apr 4, 2010 | 09:01 PM
TX Silver's Avatar
TX Silver
New tires are Kumho Venture AT LT285/75R-16 "D" load rating.
By "stock" I meant V/B code springs with Bilstein shocks.
Tire pressure is in the low 50's I started in the 60's and went down until I got a good contact patch on the ground. It did seem to make a small difference when the pressures went down (for the better).
I had good luck with Kumho tires on the last car, but am starting to second guess putting them on the X.
I appreciate the info.
TX
Old Apr 4, 2010 | 10:32 PM
03-6L-X's Avatar
03-6L-X
TX
D rated tire are not good. JMO
Running at or below what Ford reccomends is not the best. Ran my originals at 65psi and have 99k plus on them. They are E rated tires.
What may work well with a "car" may not be the best for our "land based aircraft carriers". JMO also.
Old Apr 5, 2010 | 07:27 AM
TX Silver's Avatar
TX Silver
What were the OEM tires on an X?
Old Apr 5, 2010 | 08:12 AM
jh818's Avatar
jh818
You can go to Costco.com under auto and click on tires. Enter your year/make/etc. and it will give you the OEM tire size and load range.
Old Apr 5, 2010 | 09:08 AM
03-6L-X's Avatar
03-6L-X
Mine were 265-75-16 E Rated.
Old Apr 5, 2010 | 11:26 AM
TX Silver's Avatar
TX Silver
Sorry, guess I should have worded it different.
What brand of tires were OEM?
I know the tire thing is subjective, but I'll go with what is known to work if they did from the factory.
TX
Old Apr 5, 2010 | 11:32 AM
Forest's Avatar
Forest
TX
On both my 2003 and my 2005, they were BF Goodrich Rugged Trail T/A Load Range E. Tire Rack also shows that the Pirelli Scorion STR A was used.
Old Apr 5, 2010 | 12:19 PM
TX Silver's Avatar
TX Silver
Thanks for the help guys. Now it's time to wear down the tires as quickly as possible so I can replace them...
TX
05SuperFord
Jan 12, 2014 09:10 AM
chambers1517
Apr 20, 2010 10:14 AM
bad booger
Sep 25, 2009 08:00 PM
Big Sherm
Feb 18, 2008 07:43 AM
rivershark33
Sep 19, 2007 12:25 PM
