One More Question
Old Mar 30, 2010 | 12:59 PM
superglide04's Avatar
superglide04
One More Question
Dont meen to be a post ***** but please key in for eveyday driver mods you feel would help>
Thanks 4 your time
Old Mar 30, 2010 | 01:49 PM
HH60FE's Avatar
HH60FE
I'd say keep it simple for a bit. Air filter mod and muffler deleate, if NY allows that due to any inspections. Then you need to decide what direction you want to go with your truck. Race, fuel economy or heavy towing. That will point you and us in the right direction.
Old Mar 30, 2010 | 05:08 PM
superglide04
Well ive had the truck for 7 years now did the K&N (I know big mistake) and a 4" turbo back Im looking for a bit more I use the truck as a everyday driver and I also tow alot with it and wanted to know if there was anything worth while out there.
Thanks Steve
Old Mar 30, 2010 | 05:39 PM
big poppa's Avatar
big poppa
Look into the CCV mod, it will clean things up under your hood, oily spider and intercooler boots will stay clean. Clay at RiffRaff diesel sells the kit and its a money friendly mod. Mines my daily driver also but PMS= Powerstroke Mod Syndrome hit me pretty good as you can see in my sig.
Old Mar 30, 2010 | 08:14 PM
frdf250's Avatar
frdf250
on that CCV mod i did mine for like 20 bucks or so.
go to the hardware store get 90 degree elbo,
3 band clamps
10' of heater grade hose and some hose clamps.
i would recommend getting a 4" piece of 4" exaust pipe (dont use PVC pipe it will melt.)
take your intake connection off going into the turbo, use a short philips size screw driver to remove the dog house off, make sure your 0 rings are ok under there if they arent replace them, i found it was easier to connect the 90 degree elbo before i reinsalled everything. clamp that down and screw in your doghouse. run your heater hose over the brake master cylinder and down under your cab, make sure it is always in a negative decending direction. once you have all that done, cut your 4" exaust pipe to about 3-4 inches. this will replace the CCV part that was inbetween the filter and the turbo, pop that in clamp everythign back down and your good to go.
there is more threads on this that probally have a better description but i figured it would kind of give you an idea
Old Mar 30, 2010 | 10:35 PM
HH60FE's Avatar
HH60FE
Didnt realize youve had it that long. Guess I assumed you had just gotten it and was starting out.
Old Mar 30, 2010 | 10:47 PM
mechelement's Avatar
mechelement
I don't get the desire for the CCV mod. It seems like lots of folks complain about the smell of oil or issues with the system they rigged up after that mod.
What about the in-tank mods, HPX, air filter (might require wicked wheel) and exhaust? I've read lots of good things about the in-tank mods.
Old Mar 30, 2010 | 10:57 PM
frdf250's Avatar
frdf250
in-tanks mods are a good one too. i took my IC pipes off to paint after the truck i bought had about 135k on it, you wouldnt believe how much oil gets into that through the intake.
i like it becuase it keeps the oil out of the intake and keeps the turbo clean too. the smell isnt bad at all i have it right inter my driver door. i like seeing the smoke come out of under the cab when im at a stop sign lol. ide say do it. also do those in tanks, thats next on my list......ohhhhhh PMS and im not talkin about my girl
Old Mar 31, 2010 | 04:22 AM
ron's power stroke's Avatar
ron's power stroke
pick and choose what best fits you..
Roadside Help Network - Guides, Maintenance & Mods
Old Mar 31, 2010 | 04:54 AM
ChunderDownUnder's Avatar
ChunderDownUnder
Get a tuner. you wont look back. oh and the intank mod is a top idea
Old Mar 31, 2010 | 05:49 AM
megawatt00's Avatar
megawatt00
Before the tuner most definetly a set of gauges, boost. pyro and trans temp are the three most important
