leaking fuel???
Old Mar 30, 2010 | 12:41 PM
sand1's Avatar
sand1
leaking fuel???
my 02 f250 is leaking diesel out the tube that runs on pass. side in front off motor is that tube coming from my water fuel seperator?? is the switch going bad??
Old Mar 30, 2010 | 02:01 PM
tdpower's Avatar
tdpower
That sounds like the fuel bowl drain valve is leaking. You can get the orings and instructions here: Replacement O-rings for Ford Diesel Engines
