Coil Spring Spacer
Old Mar 29, 2010 | 09:33 PM
IMPRTKLLRZ28's Avatar
IMPRTKLLRZ28
Coil Spring Spacer
I have a 96 F250 2wd with front coil springs....I want a coil spring spacer to help with a wheel rub when turning. Cant find anything for a F250 but can find them for the f150 and bronco will these work for my truck
Old Mar 29, 2010 | 09:52 PM
fishforlife2007's Avatar
fishforlife2007
they are rubbing? are the tires oversized(when compared to stock)? or have you checked your springs? they could be worn out, and new springs would fix that.
Old Mar 30, 2010 | 12:21 AM
IMPRTKLLRZ28
They rub when the truck is at weird angles. 265/75/16 is the size on there right now. Bigger than stock i think but it looks good
