Modular V10 (6.8l)
Truck stalling. IAC Problems?
Old Mar 29, 2010 | 05:19 PM
and401's Avatar
and401
After starting in the morning the truck runs at a high idle to warm up, but at the first few stop signs leaving my house (probably the first 2-3 min) the engine dies. I start it back up and it idles properly again. Until the next stop. Also, sometimes when it is warm, it idles so low (around 500rpm) that it almost stalls. I have read it might be a sign of problems with the Idle Air Control (IAC). Is this part cleanable? Where exactly is it located? I have also seen people claiming it is a cheap part (like $30-50). I looked at Lordco today and they told me the IAC Motor was $160. Any thoughts?
Old Mar 29, 2010 | 07:20 PM
Rugby3's Avatar
Rugby3
The IAC can be bought at AutoZone, NAPA etc for about $70. It takes about ten minutes to change out. It is directly behind the throttle body you can't miss it, shaped like an L sticking up. Three bolts hold it in place.
It does sound like it's the IAC, do you have to hold the accelerator down at time to get it to start?
Old Mar 29, 2010 | 07:31 PM
and401's Avatar
and401
I have no problems with starting. Even after it stalls. Probably the best starting vehicle I've ever had.
Old Mar 29, 2010 | 07:50 PM
Rugby3's Avatar
Rugby3
Did this just start, maybe bad gas. Other things to check might be vacuum leaks, the fuel filter, incorrect idle speed. Doesn't sound like the IAC.
Old Mar 29, 2010 | 08:36 PM
and401's Avatar
and401
Can't really say if it just started. I just bought the truck (cheap) with some problems. This was one of them. Gas is new (94 octane) and already changed fuel filter (along with air filter, plugs and COPs).
Is there a difference between an IAC Valve and IAC Motor? I noticed in my service manual they call it a valve, but when I went to purchase one, they called it a motor.
Old Mar 29, 2010 | 08:39 PM
and401's Avatar
and401
Doesn't the idle speed come factory set? Is it adjustable? My OBD-II software listed the idle set for 752 rpm.
Old Mar 29, 2010 | 11:24 PM
Antelope V-10's Avatar
Antelope V-10
Yes you can clean the IAC. I cleaned mine but ended up buying one at NAPA and replacing it.
Old Mar 30, 2010 | 06:57 PM
Rugby3's Avatar
Rugby3
The nomenclature is a valve, just like your manual states. I would start looking for leaks prior to replacing the IAC. Having issues starting it seems to be the hallmark sign of a bad IAC and since you have no issues there it doesn't sound like it's the IAC.
The idle is pre-set at the factory but it could have been changed if the PO had removed the throttle body or messed with the idle screw. Are getting any codes?
Chris Braun
May 7, 2014 08:54 AM
mike24150
Jul 5, 2013 01:42 PM
Krystaldt21
1997 - 2003 F150
Mar 18, 2012 01:06 PM
Jlckb5
Nov 7, 2011 07:50 AM
unclethumbtack
May 10, 2010 09:08 AM
