factory clock?
Old Apr 19, 2010 | 12:30 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Originally Posted by Cienega32
2 questions about the wiring:
1 - Is the harness side the same style plug in both model clocks?
No the harness plugs are different between the 1980-1982 clocks and the 1983-1986 clocks, so they cant be easily swapped out.
2 - Is there any chance that an 81 Custom F100 would have a harness without a clock circuit?
No, the clock is already prewired in the main harness of the truck. The clock was an option on all trim levels, so all trucks have the wiring in the main harness. What you are missing is the harness extentions from the main harness to the top of the dash.
Look at the bottom of the dash, just below the heater control panel. you should see two empty plugs with nothing plugged into them. Those are for the clock and the courtesy lamp group. This is where the short wiring harness for the clock and the courtesy lamp group plugs in, and from there goes to the top of the dash where the other end plugs in the clock.
So to transplant a clock from another 1980-1982 truck into your 1981, you would need the clock, and the short clock harness that plugs into those empty plugs at the bottom of your dash.
Seems odd to me that production would run with two styles and I'm more inclined to think that one of the P.O.s hacked it out for a radio (judging by the 'custom' hole in the bezel) but want to confirm.
It's not comon practice to change production methods during the same year model, but it does happen from time to time. The 1981 in paticular has many different changes throughout its production year, but the clock isn't one of them.
Old Apr 21, 2010 | 04:28 AM
Cienega32's Avatar
Cienega32
Ah. An "extension/accessory harness" makes perfect sense from all angles.
The clock I have is a post-82 version that I clipped about 8" of harness with, I read that the wiring is different so I figured I would get the plug with the clock to help with the wire swap.
Had I been aware of the extension harnesses, I would have taken it from end to end.
The next obvious question is if the main harness side of that clock extension harness is the same between the 81 and the post-82?
Old Apr 21, 2010 | 11:13 AM
81-F-150-Explorer
Yes, the main harness side where the clock harness plugs into is the same 1980-1982.
It changes for 1983, and then again 1984-1986.
Old Apr 23, 2010 | 11:56 PM
Cienega32's Avatar
Cienega32
So, in other words, for my 81 to use this 84 or 5 clock, my best bet would be to find the secondary harness from an 80-82 and adapt the clock end?
Thanks for all the knowledge, 81-F-150-Explorer.
Old Apr 24, 2010 | 11:35 AM
81-F-150-Explorer
You can get the plug off the main harness of a 1983-1986, and use the clock extention, if you remove the wires from the two plugs on the 1980-1982 type, and transfere it to the new 1983-1986 type plug. The wires will remove from the plugs without cutting.
To get the headlamp on warning buzzer, and underdash courtesy lamps, you have to find one for a 1980-1982, or adapt the harness from a 1983. On the 1984-1986 the headlamp warning buzzer wires is a part of the main harness and cant be used, because the 1984-1986 headlamp warning and seat belt buzzer is one unit. 1980-1983 they are two seperate buzzers.
On the 1980-1982 the courtesy lamp harness and clock harness plugs are two seperate plugs. The 1983. they are combined into one plug, but two seperate harnesses, and the 1984-1986 the headlamp buzzer is wired into the main harness.
Old Apr 28, 2010 | 02:36 AM
Cienega32's Avatar
Cienega32
Good solid info to have. Thanks a lot!
G3angler
2009 - 2014 F150
Nov 12, 2016 03:25 PM
Fordzilla80
24
Oct 19, 2016 08:01 PM
Rusty_S
Oct 29, 2015 12:17 PM
redlightning93
Ford Truck Parts for Sale
19
Oct 26, 2015 09:06 PM
