Cruise control Buttons
Old Mar 28, 2010 | 11:59 AM
Old Hickory's Avatar
Old Hickory
Question Cruise control Buttons
I have a 1996 Explorer Limited 5.0 that I bought new. The buttons on the
steering wheel that control the cruise control are badly deteriorated and one actually had a piece crack and fall out. Does anyone know if new
buttons can be purchased and how to go about changing them? Thanks.
Old Apr 1, 2010 | 04:56 PM
Old Hickory
Anyone at all have this problem or know anything about where to get parts to fix it?
Old Apr 1, 2010 | 08:04 PM
scucci's Avatar
scucci
Available at team Ford Parts:
Team Ford Parts Online- Ford OEM Parts at a discount
Old Apr 1, 2010 | 08:13 PM
Old93junk's Avatar
Old93junk
If you need to go cheap, you can find them at the salvage yard..........remember, Rangers use the same part.
Old Apr 2, 2010 | 06:37 AM
Old Hickory
Thanks Scucci for the info. The price is not bad on the new parts and I am afraid used
might be about like mine. Thanks again.
Old Apr 4, 2010 | 01:25 AM
Moto Mel's Avatar
Moto Mel
If you go to your local Pick N Pull you will only pay about $10 for the set and they are very easy to change out, but Ford used what appears to be the same inits on a lot of cars and you must know what you are looking for as the wiring connections vary between models. Otherwise only 2 8mm bolts holding the air bag to the steering wheel and 2 screws on each assy. to remove and install.
Disconnect the battery before messing with the air bag.
Old Apr 8, 2010 | 06:46 AM
jtorsey91's Avatar
jtorsey91
ive seen them around online. i just typed it in on google and a few things came up. i think that in order to get them out you will have to take out the airbag and stuff. i watched a how to video on youtube a while ago on a 99 exploder on how to take all of that stuff out.
