Quick Wiring Help Please!!
Old Mar 27, 2010 | 07:41 PM
TucsonTripleB's Avatar
TucsonTripleB
Truck is in pieces. I am trying to install Towing Mirror upgrade and have everything done except turn signals!! I can't find the D%MN turn signal wires ANYWHERE! I have gone through every wire in the bundle behind the driver kick panel that heads to the back of the truck.
I have a 2000 7.3 Excursion (I am assuming it would be the same as 250s and 350s).
What are colors of the left and right turn signal wires and where do I find them???? Anyone have a wiring diagram they can check for me please!
Old Mar 27, 2010 | 08:06 PM
Franko72's Avatar
Franko72
Molon Labe
PM sent...
Old Mar 27, 2010 | 08:10 PM
TucsonTripleB
Thanks frank, but I couldn't follow your link. It askes me for a user name and password. Any chance you could look at it for me and tell me the color codes for the right and left turn signals?
Originally Posted by Franko72
PM sent...
Old Mar 27, 2010 | 08:22 PM
Franko72's Avatar
Franko72
Molon Labe
This is the diagram I was looking for, hope it helps.
File Type: pdf
Old Mar 27, 2010 | 08:52 PM
TucsonTripleB
FOUND IT!!! THANK YOU SOOO MUCH!!!!
This file matches what I found on the sight you pointed me to. On that sight I found 2001 f 250. You 2003 and that 2001 are the same color schem.
I was also looking in the wrong 2 harness.
Thanks a TON!!!
Old Mar 27, 2010 | 08:56 PM
Franko72's Avatar
Franko72
Molon Labe
Thanks a TON!!!
Glad you got it sorted out Scott.
76gdmn
Electrical Systems/Wiring
Jan 30, 2015 03:01 PM
96bigblueford
6.7L Power Stroke Diesel
Sep 20, 2013 09:38 PM
Glxy66
Apr 29, 2012 08:05 AM
Undermydent
Jul 17, 2011 11:19 PM
JOEDEE44
Jun 27, 2003 03:48 PM
