I have a 06 f150 and my hot to cold is either hot or cold.. there is no in between no more, Has anyone experienced this problem yet and if so can ya give me some pointers? I do not even know how to take the dash cover off that surrounds the radio and all that, it is screless.... hope someone can help me out.
It's likely your blend door motor, it's behind the radio. I know they were having issues with them in 08, but I haven't heard of many from 06. To pull off the surround open the ashtray and grab hold of the bottom edge and gently pull it off, it's just held in with clips.
Is ther a way i can tell if it is the motor or not? Oh and i do not have a ashtray I have a small looking shelf under everything, i take it this is where the clips are? Thanks for the poin into a direction to start looking.
The clips that hold the surround on go vertically up the sides of it, just find and edge you can get a grip on and pull. As for testing you would need to probe the internal potentiometer, I’ve got to get to work but when I get back I’ll look through my shop manual for some wiring diagrams for you.
I really appreciate it, and thanks for the help. It is raing out right now so i can not get out there to work on it today i appreciate you looking this up for me, Thanks again.
ok, I am goign to investigate this today its going to be nice out... I really do appreciate the help from you. Thaks alot and i will keep ya posted on the outcome... Have a good one
