RVTech, Dicor question for you...
Old Mar 26, 2010 | 04:24 PM
TexasRebel's Avatar
TexasRebel
I'm getting around to replacing my skylight with a flat sheet of lexan.
What do you use to remove the old dicor sealant? I have the old skylight off, and found that the sheet I bought is about an inch too short... might have to make due, but I'd like to remove all of the old goop so I can put new goop under and over this sheet.
Old Mar 26, 2010 | 06:58 PM
FordxFour's Avatar
FordxFour
I used a plastic scraper, screwdriver, and a pair of pliers. Just get it off the best you can being careful not to damage the membrane. I am no longer using the dicor to repair cracked/dried out dicor. As I need to I am replacing it with EternaBond roof tape. I bought a 6"x100" roll for about $140.00 shipped about 2yrs. ago. Once you put this on you will never have to worry about seams or roof penetrations again. I just got tired of messing with the Dicor every year or two. Here is where I got mine if you are interested.
OneStep RV Roof Tape : Big Rock Supply, Quality Roofing Tools
Old Mar 28, 2010 | 05:03 PM
RV_Tech's Avatar
RV_Tech
With most Dicor removal, I have an Old Timer knife with a wide blade. I use it to carefully lift the edge and then usually roll it back with the edge of my thumb. I have never found a fast way to do it and sometimes the edge of my thumb really gets sore. I have never had much luck with plastic scrapers, but if they work for someone, I would never put it down.
If the existing Dicor is well stuck down and you can do a neat job, there is really no reason to remove all of it, but a new layer of Dicor leaves a much neater job when the temperature is warm. For example, When I reseal vents, I go over the existing Dicor since the most common problem with Dicor is it dries out and cracks over time.
Good luck,
Steve
Old Mar 28, 2010 | 07:10 PM
TexasRebel's Avatar
TexasRebel
I've got a 3" scraper that I'm trying to use.
I have most of it off, and since there is no threat of rain soon, I'm not currently pressed for time.
One problem I'm having is that the membrane is flexing more than the dicor is peeling up. My thumbs are killing me today, and there is what appears to be plumbers putty that was underneath the skylight flange.
My plan, is to remove as much of the old stuff as possible, run a new bead around the edge of the Lexan, and place the glass, then screw it down. I am going to fill any holes that don't get covered with dicor.
Doing my best to make it look like this was original, but if I can't remove all of the old dicor, it's going to look a little off.
Old Mar 28, 2010 | 07:22 PM
RV_Tech's Avatar
RV_Tech
It sounds like what you are doing is perfectly acceptable and yeah it really can wear out your thumbs. The roof membrane does tend to stretch and I try to hold it down. I like using my knife better as I have found it cuts through the Dicor better than plastic. Just as an aside, patching the rubber membrane is not a big deal, so you do not have to be overly worried. It's just nice not to add more work to your work.
The material under the the skylight is called "tacky tape" or putty tape. It provides an additional seal under the glass. Dicor will work fine to cover any holes. And - Dicor, as you may have already discovered, is murder to get out of your clothes.
Good luck,
Steve
Old Mar 28, 2010 | 10:07 PM
TexasRebel's Avatar
TexasRebel
actually, no, I hadn't found that out yet...but it makes sense.
good to know.
the scraper I'm using is stainless with an edge. I've already put one small hole in the membrane that will end up covered by the glass.
Will the old Dicor and putty help or hinder the new seal?
Old Mar 29, 2010 | 05:44 AM
RV_Tech's Avatar
RV_Tech
good to know.
I really don't think you have to worry about the old Dicor. Anything that is well stuck down is very likely to stay stuck down. Tacky tape come by the roll and is under $5.00. It should be easy to get up and I usually install new to bed down skylights or vents, before I screw them into place.
Steve
Irelands child
All Things Towing
81
Jul 13, 2016 08:39 AM
callmebobvilla
Australia Chapter
May 7, 2015 08:56 PM
beachcamperf250
Jun 26, 2014 06:32 AM
The_Blue_Guzzler
Apr 12, 2013 11:36 PM
DBGrif91
13
Oct 25, 2011 11:02 AM
