No reverse...still
Old Mar 26, 2010 | 01:42 PM
48' fordster's Avatar
48' fordster
No reverse...still
Hey all, The '95 in my sig is acting up again...I can not get the truck into reverse while it is running....I did the heim joint fix to the clutch master and it worked much better, but now it has gotten worse. What else could this be. The Disengage/engage point of the clutch is soooo close to the floor, the thing is barely disengaging. What could be some problems of this....Thanks in advance.
Old Mar 26, 2010 | 02:08 PM
ccarrier's Avatar
ccarrier
sounds like what im fixing today... clutch master cylinder
Old Mar 26, 2010 | 05:58 PM
foxracing0934's Avatar
foxracing0934
could also be a shift fork that is worn or bent. I'm no expert on the ZF but that is another possibility
Old Mar 29, 2010 | 01:43 PM
48' fordster
Where is the shift fork located and how easy a fix is it?
Old Mar 29, 2010 | 08:20 PM
foxracing0934
Sorry Alec, I really don't know much of the internals of this tranny so I don't know. You might want to shoot Travis a PM because he knows a lot more about them then I do.
Old Apr 9, 2010 | 05:51 PM
48' fordster
Bump....Where is the shift fork located, and how much of a job would it be to replace it or to inspect it, it is getting hard to shift into 1st now too. The grab point on the clutch is just way to low to the floor it seems.
Old Apr 9, 2010 | 08:36 PM
helifixer's Avatar
helifixer
measure your fork travel at the slave cylinder. the fork is in the bell housing, left side. IIRC it is a trans split to change the fork
