'89 cruise control
Old Mar 26, 2010 | 12:48 PM
ytlogger's Avatar
ytlogger
'89 cruise control
My cruise control has been wonky for years. When I want to set a speed and push the set/accel button on the steering wheel it will often go to accel and will not set. I'm thinking that the circuit board behind the wheel is at fault but the local dealer can't supply the boards because the truck is 20 years old.
I thought one of Fords claims to fame was more trucks still on the road than any other manufacturer, or that's what I told the partsman anyway.
I like the cruise as I can tend to get a heavy foot on longer drives. Any ideas for suppliers?
Old Mar 26, 2010 | 09:17 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Although I have never had the steering wheel/switches apart, my guess is 21 years of dirt/moisture have caused the switch contacts to corrode or dirt has built up on them causing a bad connection.
It may be possible to clean them and get it working again.
Without looking at the schematics, I think it would be easy to build a set of switches to control the cruise, but I may be wrong.
I would be just as happy if my switches were on the dash since the brake pedal deactivates the cruise when you touch it.
Old Mar 26, 2010 | 10:02 PM
ytlogger's Avatar
ytlogger
I've been thinking about rewiring for different switches if the stock setup is not available. 'Set' is the only circuit I use anyway. I'm not always sure that partsmen try too hard. It's easy to just say it's too old. I've had the same problem with my dozer and skidder, only to come across a more knowledgeable or persistent partsman who found what I needed.
Old Mar 26, 2010 | 10:07 PM
starmilt's Avatar
starmilt
After 10 years they can and do discontinue parts, but they have the ability to find out where one is laying in the shelf if they want to. Try ed the parts guy, I know he has gotten obsolete parts for members before.
Old Mar 26, 2010 | 10:45 PM
ytlogger's Avatar
ytlogger
Thanks starmilt, I went to their site and left a message.
Old Mar 27, 2010 | 02:10 PM
Dave Sponaugle
Another place you might look is LMC truck.
Old May 15, 2011 | 01:11 AM
wrd0225's Avatar
wrd0225
I found some the junk yard. Opened the steering wheel. They looked new, hardly used. Tested them and they worked fine.
westcar360
Oct 19, 2019 06:45 AM
AbandonedBronco
1978 - 1996 Big Bronco
13
Oct 31, 2010 09:30 PM
Twistedtesty
Jul 18, 2010 02:43 PM
bitesomthing
Sep 30, 2004 01:54 AM
ranger429
May 27, 2004 09:25 PM
