Poor spark?
Well after I swaped the motors it ran well. I was happy, but the carb needed a rebuild so I didn't drive it much and parked it for a month, starting it from time to time. Well one day I went out to start it and it started to fire but then died! Dosn't want to pop anymore. I pushed it in my shop and I was able to get it to start for a second or so with starter fluid and I messed with the timing. Now it dosn't want to pop again.
I don't have anyone around to hit the starter while I hold a spark plug to the block to check spark. I did have a harbor freight spark plug light but seems like the bulb just lit up a little bit, should it flash brightly?
I'm starting to suspect the coil but I don't want to spend $$$ on replacing parts. I checked all the usual stuff and it seems fine via visual inspection.
Any suggestions? Can 'shucks' test my coil? I'm going to get a new cap and rotor as mine is a little worn anyways. I don't know if I will get wires as they seem great.
Thanks guys - I'm very frustrated with this rig right now...
