Maual primer on fuel pump?
I finally got around to installing a system like this and no more problems! I have it on a hard switch, so once she's up and running, I just turn the pump off. It is such a relief to have this worry taken care of. Thanks for the help, Marianna.
Will this guy work? Airtex E8012S - Electric Fuel Pump | O'Reilly Auto Parts
I heard to recommended somewhere...
Should work. The pressure is about right. But I can't stress it enough to use a relay and inertia switch! I never used to worry about either but last yr I almost burned my truck up with just a switch. Also a buddy rolled his buggy, The engine quit but the pump kept running. It was almost a deadly disater.
That's funny. That pump was developed for the OE on the 5.7 Oldsmobile Diesel jokes. They were adapted to gasoline use by adding a teflon ring on the plunger. Some parts men speak with forked tongue.
on
and ditch that fuel filter for a barbed fitting.not if,but when that little sucker gets plugged,it will burn the pump up in no time im sure.
the black mr.gasket is not rated for diesel fuel either,only the green model #12D is.
https://www.ford-trucks.com/forums/8...-terminal.html
#29
#30
on
according to Dave,no matter where you get power,it should be be used to open a relay only,and draw from a line directly pulled from the battery,with a fuse just after the terminal.
perhaps the cruise line is only used for that,and since its not being used anymore it might be ok....i just don't know.
after it was explained to me how to do it,and i see how it works,there's simply nothing better than that setup.- for a fool proof,turn key and go install.
and actually,im not sure if thats a good line to use for your trigger either.doesn't cruise only work at a certain speed,and go off with your brakes? i guess the line where you tapped into it,may be juiced all the time......man,i dunno if i would have picked that line to use for a pump.any rate,you'll probably burn up your cruise switch if you dont put it on a relay,and draw directly from the battery.
you best bet is to just follow how i did it,and then you'll never have to mess with it.just turn the key forward,and it starts pumping/no need for a devoted switch.
