Have questions?
Old Mar 25, 2010 | 12:40 PM
JohnSChisum's Avatar
JohnSChisum
Have questions?
New to the diesel section of the forums. I just purchased my second 80's F250 this one is a 84 with a 6.9 4x4 with a c6. It has a front clip from a 91 and the box of a 97. I drove it home about 35 miles without power steering(its there,but not hooked up) and with no exhaust(once again there, but not attached) I have already replaced the exhaust, but due to a surprise fuel leak I cannot start yet. I am unaware if rear tank works. P.O. says it does, but his son says unknown.
The first couple of questions I have are...
1. I have a box off a 97 on the truck now, but need to change the front tank as it has a bad leak. Does anyone know if the tank from a 95 will fit my 84 frame/97 box setup? I am especially concerned about the filler tube lining up.
2. Does anyone know if the power steering pump tension adjuster is the same off a gas engine and which size would work?(302/351) I have access to both of those.
Any help would be great.
Old Mar 25, 2010 | 05:21 PM
JohnSChisum
power steering assembly and pump interchange with a 1982 Bronco 302 fyi as well as about 15,000 parts. Traded a snowblower for a donor.
Old Mar 25, 2010 | 09:06 PM
rupejosh's Avatar
rupejosh
you might try measuring where the filler neck is in relation to the front of the bed on both boxes.everything should line up though
