Tachometer Problems?
Old Mar 25, 2010 | 08:36 AM
banjopicker66's Avatar
banjopicker66
On my '89 F-250 with E4OD, the tachometer goes to zero at idle, and bounces a bit. Where is the tach sensor, and is there a TPS on this thing?
Thanks!
Old Mar 25, 2010 | 09:16 AM
farmert's Avatar
farmert
The tach sensor is located on the ip gear cover just to the right and behind the oil fill spout. It is the one inch nut with two wires coming out of it. You can remove it anc wipe it clean which might help it, but mot likely you need a new sensor. a Ford only item.
I'm not an auto guy so I can't help on the tps, other than I think it is on the throttle linkage.
Old Mar 25, 2010 | 09:29 AM
Sycostang67's Avatar
Sycostang67
I believe there is a tps on the E4OD trucks, but I think its called an FLPS(Fuel level position sensor). I'm pretty sure it's on the IP attached to the throttle lever.
BGF100
Oct 15, 2016 09:58 AM
bbierschenk
Jul 7, 2015 09:12 PM
19711969
Mar 22, 2015 05:43 PM
rclarke
May 25, 2014 10:49 PM
miashley150
13
Aug 22, 2013 11:34 AM
