I have a 2001 Expo and as of today the interior lights are staying on. I have lubed up all the latches and have had no luck. On thing I did notice is that when all the doors are closed and you start it. The lights seem to dim sum but still stay on. Looking for Ideas?? Or places to look Just to add the door adjar light is off.
did you try the the switch next to the headlights? if its all the way turned up than your lights will stay on, the switch is used to dim dash lights and also to turn in the interior lights
Yes already tried that. I can even here the relay kicking off after so many seconds but the lights are still staying on. Almost like it is getting power from some where else.. Need a schematic
