hindsight 20/20
Old Mar 24, 2010 | 04:51 PM
kyf100's Avatar
kyf100
hindsight 20/20
i'm in the process of rewiring my 56' and would like to clean up the firewall in the process by putting the volt reg.,horn relay and everything under the dash. has anyone done this and wished they had done anything different after they got done ? thanks
Old Mar 24, 2010 | 05:32 PM
Julies Cool F1's Avatar
Julies Cool F1
It's better to leave them in the engine compartment for a number of reasons. First, they can get hot and it's better to have them in a space where there is constant air circulation.
Second, they carry some high amperages. It's best not to chance pulling the wires that carry those amperages through the firewall and possibly having a chaffed wire do some welding on your truck without permission.
Third, they will be difficult to access up under the dash - there's already a bunch of stuff up ther trying to bump into one another.
You can clean up the look quite a bit by mounting the units and making sure your wires are neat and bundled with nylon ties or plastic conduit, not electrical tape. Run all your wires along a single path and mount the boxes along that path. I took all of mine out of the cab through the grommet on the firewall on both the left and right sides then ran the bundles down to the frame to have them branch out. So I only have two wire bunches - very clean.
Old Mar 24, 2010 | 08:38 PM
Old F1's Avatar
Old F1
Why not kill two birds with a great big hunkin’ rock?
If you have a regulator then you should (?) have a generator, if you want to put stuff under the dash to clean up the ugliest fire wall in the world (generically speaking) and who wouldn’t, then you are starting down the road to the scary dark side, take a small jump down it and install a single wire alternator (that actually charges at a idle, strange concept) with a built in regulator and make your firewall NAKED .............as it should be.
Aquapools
2015 - 2020 F150
Sep 22, 2014 09:23 PM
BarnettMan85
Oct 13, 2013 04:34 PM
bcrewcaptain
Apr 4, 2009 05:51 AM
cajun450
New Member Introductions
Nov 25, 2008 08:41 PM
pward76
Appearance & Dress-Up
Apr 30, 2004 12:56 PM
