Mine won't stay in 4lo??
The other day I needed to climb a bank, so I squared in up put it in 4 lo and proceeded up the bank, but it popped out of 4lo. but it back it popped out. So I held it in , it stayed in. I was able to get it up the bank. I was thinking the linkage was out of adjustment. reason for that the lever didn't feel like it was locking in. I haven't looked into it, since I was able to do what I needed to do in 4hi using the granny gear.
actually this is the first time i've ever driven/used the truck since I traded for the truck. The truck seemed to have been somewhat taken care of, and really wouldn't see why there might be something wrong with the T-case. So I ask, hope some of you guys can suggest some possibilties.
Typically each case ill have an identicication tag, and this is the easiest to help identify.
Shift lever(s) location is a decent visual way. 203 will have two levers located on the driver side of the case, and a 205 will have two rods that insert into the front of the case. The 203 will have two linkages that connect to the transfer case, and the 205 will have just one.
A 203 is a multi piece case with a range box that bolts up to the front of the chain housing. This is probably a little more difficult to see if you dont have two cases to compare.
A 203 has a huge housing over the rear output, and the 205 has a small one that simply retains the brearing and seal.
Perhaps just a picture of what you have will be an easier thing to do.
