PYRO VS TEMP GAGE???
Old Mar 23, 2010 | 10:37 PM
idahodisco's Avatar
idahodisco
I have to know! So if your temp gage is in the M of normal what does your Pyro say?
Old Mar 23, 2010 | 11:05 PM
swooshcmk's Avatar
swooshcmk
I don't have a pyro yet, however I don't think you'll find much of a correlation between the two unless you're on the verge of meltdown.
The coolant temp of the engine will depend on the temperature of the thermostat being used, the ambient air temperature, how well the cooling system is working, not to mention the variances in the temperature gauges. Aside from that temperature rise of the coolant will lag the EGT's by quite a bit and EGT depends on how far your foot is in it as well as the load on the engine...
Now perhaps if you rephrase it such as...
"1986 C6 with 3.55 at 65mph, what are your EGT's at steady state flat ground" you might get a little closer to what you're looking for I think?
Old Mar 23, 2010 | 11:08 PM
rodneywar's Avatar
rodneywar
NO CORRELATION BETWEEN THOSE TWO WELL WHAT SWOOSH SAID
Old Mar 23, 2010 | 11:49 PM
idahodisco's Avatar
idahodisco
So if I had my gage at the N on normal I could have a meltdown on my heads going on?
Old Mar 23, 2010 | 11:53 PM
rodneywar's Avatar
rodneywar
YEA YOU COULD IF YOUR EGTS ARE HIGH ENOUGH!!!
Old Mar 23, 2010 | 11:54 PM
rodneywar's Avatar
rodneywar
About 1050 to 1100 is about max. Aluminum melts at 1225 or so. Plenty of damage happens when they get soft and the combustion hammers them.
Old Mar 23, 2010 | 11:59 PM
idahodisco's Avatar
idahodisco
Originally Posted by rodneywar
THE PISTONS ARE ALUMINUM I THINK 1200 IS TOO HIGH FOR EM
OK OK YOU DONT HAVE TO YELL!! But realy I cant wrap my mind around it! Well I still want one story like my gage was on the m and I was at 1000 on my pyro! LOL
Old Mar 24, 2010 | 12:00 AM
rodneywar's Avatar
rodneywar
I WASNT YELLING MY CAPS LOCK IS BEING A BIT#CH RIGHT NOW!!!
Old Mar 24, 2010 | 12:07 AM
idahodisco's Avatar
idahodisco
OK BUT MY EARS ARE RINGING LOL!!! DAMN IT STOP TURN OFF YOUR "CAPLOCK"
Old Mar 24, 2010 | 12:16 AM
rodneywar's Avatar
rodneywar
got it fixed got a screwdriver and ripped it out no joke now its permantly off!!!
Old Mar 24, 2010 | 12:26 AM
idahodisco's Avatar
idahodisco
lol time for target!
Old Mar 24, 2010 | 01:00 AM
starmilt's Avatar
starmilt
Yes your pyro can hit a 1000 even before your engine hits operating temp if you're mean to it. The pyro is measuring the gas temp coming out of the cylinder it can move up and down extremely quick. For instance if you mash the go pedal in a high gear and you are at a low speed the pyro will climb quick until you get enough rpms to get the air in to burn the fuel you are giveing it. If you are climbing a hill and keeping it on the floor and barely holding your speed or even loosing some your pyro will be climbing quick. let off the fuel and it will drop even quicker.
Old Mar 24, 2010 | 01:26 AM
idahodisco's Avatar
idahodisco
Ok look at this all heat gages are good but pyro 1050!!
YouTube - Powerstroke Punishment
Old Mar 24, 2010 | 01:29 AM
Sycostang67's Avatar
Sycostang67
I pulled a 25' camper up lucky peak hill riding 1100* on the pyro and my temp guage never moved.
