Sponsored by: Real Truck
leveling the front
Old Mar 23, 2010 | 05:57 PM
furret's Avatar
furret
leveling the front
Do you recommend that kit to level the front of a 2000 f-350.....what are the
PRO and CON......
thank
Old Mar 23, 2010 | 05:59 PM
furret's Avatar
furret
PRO and CON......
thank
Sorry here the link..FORD F-250 F-350 SUPERDUTY DIESEL GAS SHACKLE LIFT KIT on eBay.ca (item 230441496450 end time 25-Mar-10 11:33:38 EDT)
Old Mar 24, 2010 | 09:50 AM
SGnAZ's Avatar
SGnAZ
That's a good deal.I think you will be ok .
Welcome to FTE.
Old Mar 24, 2010 | 09:57 AM
scottzj's Avatar
scottzj
Hangin 10 bra
Well problem with leveling kits is they tend to raise the front end up too high compared to the rear. Then a 1" block is needed for the rear to level it completely. I guess it just depends on truck.
Old Mar 24, 2010 | 10:51 AM
SuperDutyScaler's Avatar
SuperDutyScaler
i would so no, why do you want to keep the old sagging front springs? just buy a set of x codes and put energysuspension bushings in them and forget it. we put skyjacker two inch spring kit on my dads 2000 350 and he hated it. last month i got the x codes put in poly bushings along with the poly sway bar bushings and it better now than it ever was
Old Mar 25, 2010 | 09:42 AM
SGnAZ's Avatar
SGnAZ
Where did you pick up the x-codes?
Thanks
