tranny swap
Old Mar 23, 2010 | 05:43 PM
generaltso64's Avatar
generaltso64
tranny swap
Anyone thats done it, will a t19 out of a 83 6.9l fit my 7.3idi?
Old Mar 23, 2010 | 05:45 PM
johnboggs21's Avatar
johnboggs21
should bolt right up i think
Old Mar 23, 2010 | 06:24 PM
starmilt's Avatar
starmilt
You will have to use the bellhousing, and maybe even the flywheel and clutch.
I have read a ford bulletin that says you can't swap the flywheels between the two because of the balance, I'm assuming it is fine if you swap the balancer too, as the crank is the same. I didn't read thes bulletin for several years after I used a 6.9 flywheel on my 7.3 and have had np bad effects from it.
