Sponsored by: Kumho
Need help with brake gremlin
Old Mar 23, 2010 | 03:18 PM
meck1's Avatar
meck1
My '87 F250, 2wd, has started with a steering wheel oscillation and slight shake when I'm braking. It's the feel that I've had several times with cars when they were needing new rotors or old ones turned. The mystery, though, is that this only happens when I'm braking as I go down a fairly steep incline. Any other time, level ground or going uphill, everything is fine. I've checked the brakes out and they look okay. I didn't use a dial gauge on the rotors but when I spun them next to a fixed point there was no obvious runout. Can anyone give me a hint as to what is going on here? Thanks.
