NEED QUICK HELP!!!
Old Mar 23, 2010 | 03:08 PM
idahodisco's Avatar
idahodisco
NEED QUICK HELP!!!
I just changed my mechanical fuel pump and it wont start??
What could I have done wrong??
Old Mar 23, 2010 | 03:10 PM
polarisman729's Avatar
polarisman729
Your fuel system primed??? You getting fuel to the injectors? OR at least to the fuel filter housing. It will probablly take a while to get everything fueled back up. Fill the filter with powerservice and that should get you enough to get it fired and let everything get filled up.
Old Mar 23, 2010 | 03:12 PM
rodneywar's Avatar
rodneywar
CRACK OPEN THE INJECTOR LINE AND AND CRANK IT TILL IT STARTS THEN CLOSE THE LINE THATS HOW I DID MINE!!
rodneywar's Avatar
rodneywar
DONT FORGET TO LET THE STARTER COOL BETWEEN CRANKS
Old Mar 23, 2010 | 03:21 PM
jmmartin's Avatar
jmmartin
ditto on the crack fuel lines... if you dont it will take FOREVER and a year to get it to crank.
Old Mar 23, 2010 | 03:29 PM
starmilt's Avatar
starmilt
Make sure you're getting fuel to the schrader valve on the filter, some members have reported installing the pump with the arm above the pump lobe instead of under it. There has also been cases of new pumps being bad.
Old Mar 23, 2010 | 04:01 PM
idahodisco's Avatar
idahodisco
Ok I got it!!
I open up one of the vavles on top of the fuel filter and injected some more diesel in it untill it ran out! Started right up!!
Thanks for the quick reply guys! I am going for a test drive wish me luck!
Old Mar 23, 2010 | 05:48 PM
rodneywar's Avatar
rodneywar
Cool Good luck!!!
Old Mar 23, 2010 | 05:59 PM
starmilt's Avatar
starmilt
How about a picture of that valve.
Old Mar 23, 2010 | 07:43 PM
idahodisco's Avatar
idahodisco
I was going to but it wants a HTTP: address??? How do I do it?
I could email to someone and they can post if that easy!
Old Mar 23, 2010 | 07:47 PM
johnboggs21's Avatar
johnboggs21
email it to me and ill post it up for ya
johnboggs21@yahoo.com
Old Mar 23, 2010 | 07:53 PM
idahodisco's Avatar
idahodisco
I just sent it Johnboggs cant wait to find out what it is?
Old Mar 23, 2010 | 08:17 PM
johnboggs21
it must have got lost in cyberspace or somethin, i got nothin? try sending it one more time.
Old Mar 23, 2010 | 08:27 PM
idahodisco's Avatar
idahodisco
I just sent it!
Old Mar 23, 2010 | 08:50 PM
johnboggs21
huh nothin yet. maybe theirs major lag happenin
