Old 11-17-2014, 06:09 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Electrical Guides
Print Wikipost
TPS - Throttle Position Sensor FYI
  #31
Old 02-17-2012, 09:39 AM
mezcalero280cal's Avatar
mezcalero280cal
mezcalero280cal is offline
Hey Payson, does this also hold true to a 1997 f-350 7.3 with an auto e4od ? MY TPS WENT OUT AND IT IS LOCATED ON THE PEDAL ALSO . Only difference is the tps is high up on the pedal assembly and the ivs is lower down on the pedal so they are not together like to ones on your picture. I got a tps from O'Rilley's that was identical to the old one but it didn't work. Am I missing something here ?Ford dealer says you can't buy it separately and they are asking $459.00 for the whole pedal assembly... Too much money for my pockets...
  #32
Old 02-17-2012, 10:41 AM
PaysonPSD's Avatar
PaysonPSD
PaysonPSD is offline
I do not know if it will work on any model but my 99 because that is the only truck I put one on.
Ed did tell me he had quite a few returned TPSs because they wouldn' work.
The TPS I installed is till working just fine after almost 2 years.
  #33
Old 02-17-2012, 10:45 AM
mezcalero280cal
tps
Thanks man I will keep trying....
  #34
Old 02-18-2012, 10:16 AM
johnsjsj's Avatar
johnsjsj
johnsjsj is offline
TPS
WHO CARRIES A GOOD TPS FOR A 2002 BESIDE FORD STEALERSHIPS
  #35
Old 02-18-2012, 03:35 PM
mezcalero280cal
Did you have to do any adjustments to the tps or did you just install it out of the box ?
  #36
Old 02-18-2012, 03:38 PM
PaulDH's Avatar
PaulDH
PaulDH is offline
Simply install on my 2001.
  #37
Old 02-19-2012, 11:33 AM
PaysonPSD's Avatar
PaysonPSD
There is a pivot pin with a flat end, like a screwdriver, in the trottle assembly that rotates the TPS potentiometer when the pedal moves. Just make sure the TPS engages it. Don't know how it could be installed properly without doing that because you have to engage the pivot pi and then slightly twist the TPS to get the TPS torx mounting screws lined up. Once installed there is no adjustment.
NewOldTPS.jpg?t=1269362105
Glad to see there is someone else that has installed the separate TPS and can attest to the fact it works.
  #38
Old 04-09-2012, 08:37 AM
glebreton's Avatar
glebreton
glebreton is offline
Wiring...
I am trying to switch out the same pedal assembly you pictured. I am going from the older 2 connector to the newer single connector with 5 integrated wires. Bad thing is the new wiring harness has 10 ALL WHITE leads coming off of it. I planned on matching the wire colors from the new harness to where I cut the wires from the vehicle, so now I don't know which wires should connect to the factory wires coming off the Excursion. Anybody with the single connection pedal installed care to post a pic of the wiring connected to the single harness head? I know I only need 5 wires connected, not all 10 that came with the new head. Thanks in advance...
  #39
Old 04-09-2012, 10:30 AM
mueckster's Avatar
mueckster
mueckster is offline
Let's try this again. lol Had trouble with uploads.
  #40
Old 04-09-2012, 10:46 AM
mueckster's Avatar
mueckster
Pic of the plug and pdf of the wiring diagram
Name:  002 (800x600).jpg
APP Sensor wiring.pdf
  #41
Old 04-09-2012, 11:09 AM
Kajtek1's Avatar
Kajtek1
Kajtek1 is offline
I have one of those PPS, or TPS that I bought from TechChoice Parts Distributors, LLC for my e99 model and it did not work. TechChoice stop replying to my emails after I asked for my money back, so I am stuck with it. If anybody wants to check it on newer model, I can mail it with no money and if it works, you pay me what you think is right. PM me with your email address if interested.
What is says on it is 699-201 and 51984 CHN and has 3 prongs
  #42
Old 04-09-2012, 12:38 PM
glebreton's Avatar
glebreton
Attachment 53037
Attachment 53038
Thanks a million for the pic and quick reply. That is exactly what I needed!
  #43
Old 04-10-2012, 06:09 AM
glebreton's Avatar
glebreton
Attachment 53037
Attachment 53038
Once I got the wiring sequence, I was able to pull the old accelerator/APS/IVS, rewire the harness, and install the new accelerator in an hour! FWIW, I posted the same question on another Ford forum and have been waiting a week with no response. On FTE, I got pics and PDF file in about 6 hours. I like this place!!!
  #44
Old 04-10-2012, 10:27 AM
SpringerPop's Avatar
SpringerPop
SpringerPop is offline
That's what really sets FTE head and shoulders above most other automotive sites.
I also have a couple of Hondas, and went looking for answers on a couple of those forums. I guess I expected a similar experience. What a disappointment THAT was!
Yours is not an unusual case. We all learned something from it, and it will continue to be here for next time.
Stick around and participate. You can add to the collective knowledge that makes FTE what it is: a cut above.
Miles above......
Pop
  #45
Old 06-09-2012, 10:45 PM
ioflo's Avatar
ioflo
ioflo is offline
tps F350 -2000
Hi, can someone help me pls? i am looking for a Tps sensor and i don't know where i can buy it from? i live near Philadelphia thank you
Quick Reply: TPS - Throttle Position Sensor FYI
