Wheel backspacing
Old Mar 23, 2010 | 10:07 AM
jpcjguy's Avatar
jpcjguy
Wheel backspacing
Hey all,
So I found a set of Weld Outback 16x10 rims with 35x12.5x16 Cooper discoverer STT with 65% tread - $500 for the set!
I am stock height now (2002 Limited with 7.3) and will probably do the lift like YellowSled (Same rims as him! - love the look) Here is the thread:
https://www.ford-trucks.com/forums/8...ims-tires.html
This is the procomp 22210 springs up front and 5.5 tapered block in the rear.
The wheels have 3.5 backspacing - is that ok? I don't mind a little rubbing as I will never take her off-road - that is what my CJ7 with 1 tons and 38 Swampers is for! Stuffing a tire completely is really not going to happen....
What do you all think?
Old Mar 23, 2010 | 10:55 AM
CanadianSmokie's Avatar
CanadianSmokie
You will be more than fine. The acceptable backspace is around 4". Anymore and you'll be risking rubbing on the leafs.
Offset is calculated using + or - measurement (in mm) from the theoretical centerline of the wheel. Backspace is a direct measurement from the back lip of the rim to the mounting face.
BACKSPACE
OFFSET
Old May 1, 2010 | 07:54 PM
AndeyHall's Avatar
AndeyHall
Ok, so what is the possitive or negative range that the 99-04 super duties can accept after being leveled?
Old May 1, 2010 | 09:26 PM
CanadianSmokie
Leveling your truck won't affect the backspace requirements of your wheels. Most, if not all, rims for trucks are listed with backspace numbers ie: 3", 4.5" etc... the bigger your backspace number the more the inner lip of your rim is going to get to your springs. Stick with a 4" backspace and you'll be fine.
Old May 1, 2010 | 10:27 PM
nyvp's Avatar
nyvp
what about with a 2wd what backspace is ok with no leaf's
Old May 1, 2010 | 10:59 PM
AndeyHall's Avatar
AndeyHall
So <=4"...awesome. What about if they use the term "offset" instead? What kinda numbers would I be looking for there?
Thanks for the info so far man.
Old May 2, 2010 | 12:33 AM
william_04_x's Avatar
william_04_x
This is a pic of 305/50/20's on 20x10's w/ 4.5" BS on the rear of my stock height 2WD X.
Old May 2, 2010 | 05:57 AM
nyvp's Avatar
nyvp
william_04_x do you have pictures of front and one from behind so i can see the difference and how much they stick out?
thanks so much.
Joe
Old May 2, 2010 | 09:35 PM
AndeyHall's Avatar
AndeyHall
Ok, so i did a search for threads on backspacing, and that's how I wound up here. However, I just realized I was in the Excursion forum, haha. Anyways, the brand I was recommended was Centerline, because it can handle excess weight. Does anyone know if this should work on the 99-04 trucks with leafs on the front?
Center Line Wheels
Old May 2, 2010 | 10:03 PM
william_04_x
thanks so much.
Joe
I don't have any, but I can take a couple. I don't run these wheels and tires all the time. I have a pair for the rear when I go to the track. I'll mount them on the front of the truck to see if they rub. I would imagine they will because the tires are +12" wide. I want to do this anyways as I want to run these wheels on the street with a bit smaller tire.
Center Line Wheels
The wheels I pictured are Centerlines. Their site recommends the 4.5 backspace(depending on diameter) for 99-04's, unless you are lifted.. Give them a call, they're cool people.
VitaminC
19
Jul 15, 2017 04:42 PM
aj1434
Dec 22, 2016 05:36 PM
prkranger
May 19, 2016 02:03 AM
Tiptonite
Apr 21, 2016 06:08 PM
smarty39
Aug 28, 2015 11:26 PM
