2000 Excursion No/Little Heat
Old Mar 23, 2010 | 10:00 AM
stevepeters23's Avatar
stevepeters23
My heat recently went out in my 2000 Excursion w/ 155,000 miles. I can get to the front heater core through the glove box and it gets hot but as the air is pushed through it the core cools off significantly, especially through the center of the core. The blend doors are functioning properly. The rear heat is doing the same thing so I've mostly ruled out a clogged core. What does this sound like to you all?
Old Mar 23, 2010 | 10:54 AM
tdappleman's Avatar
tdappleman
The Excursion has a vacuum operated valve on the heater core input hose. When the A/C is turned on it shuts to boost the performance of the A/C. It should be open when the A/C is off and you have the heat on. May want to look at it and see if it is opening correctly when the modes are switched. I'm not 100% on if it also impacts the rear heat but is certainly an easy item to check as a starting point.
Here's a picture of mine:
thurston
Nov 26, 2015 11:13 AM
brobrad
1997 - 2003 F150
Jan 27, 2015 08:17 PM
jagger blaze
1997 - 2003 F150
Nov 18, 2014 09:40 PM
Buggie
Oct 31, 2013 11:28 PM
bigal1
1997 - 2003 F150
Jan 28, 2013 10:47 PM
