Intake question
Old Apr 2, 2010 | 12:51 AM
Bear 45/70's Avatar
Bear 45/70
Originally Posted by YoungMT Hick
ok found a C8AE-F "S" intake from a later than 66 model something i was told. so the ports should match up but what is the big S for ???
Well it is a 1968 (C8) manifold and will work on the 1966 and later small port heads. The "S" designates it was originally on a car motor. The trucks had a "T" but the manifolds are identical.
Old Apr 2, 2010 | 02:30 PM
YoungMT Hick's Avatar
YoungMT Hick
so i take it this is a good intake to put on the truck matched to the edle 600cfm????
Old Apr 2, 2010 | 04:25 PM
Bear 45/70's Avatar
Bear 45/70
No Ford truck with an FE ever came from the factory with a Carter carb (that's all the Edelbrock carb is just a Carter carb). But the 600 CFM is the same size Ford used with their Holley and Motorcraft carbs.
Old Apr 2, 2010 | 04:42 PM
MeanGene427's Avatar
MeanGene427
Actually a CJ manifold WILL work with the late heads, as the CJ is basically a Police Interceptor intake cast in iron instead of aluminum, and with the newer high, short ports, and is a very good running intake- just heavy as hell. The mismatch did not hurt anything with the high port dumping into the old-style long port of the CJ- Low Riser type head, as smaller went into larger, and the bottom of the "long" port is dead air anyway- CJ's came that way from the factory. Trying to run an early intake on late heads is where you have a problem, large dumping into small. No such thing as an "SCJ" manifold, same intake used on both.
IIRC, seems like the Holley used on the pickup 390's was a little buggar, not 600, like 390 cfm. 600 cfm Holley with "cathedral" bowls was used on the 390GT car engine
Old Apr 2, 2010 | 05:32 PM
Bear 45/70's Avatar
Bear 45/70
The CJ heads have ports much taller than the 360, 390 & standard 428 heads.
390 heads are 1.34" X 1.93"
PI manifold is 1.34" X 1.93" same as the "S" manifold.
CJ manifold is 1.34" X 2.34"
Som the PI and CJ are not the same at all.
Old Apr 2, 2010 | 10:01 PM
MeanGene427
"The mismatch did not hurt anything with the high port dumping into the old-style long port of the CJ- Low Riser type head, as smaller went into larger, and the bottom of the "long" port is dead air anyway- CJ's came that way from the factory."
As you can see if you look, that's what I said- the CJ HEAD had the long Low-Riser port, as it's basically a revised Low Riser head- the CJ manifold DOES NOT- it has the 1.93 port. Got a genuine one dated November '69 out in the shop
LATE 390 heads are 1.93"- EARLY 390 heads are 2.34"
The late C7AE Police Interceptor manifold has the high, short 1.93" ports- I have one, just loaned it out for a dyno session on a 482 with Shelby aluminum MR type heads. It also still had the hole in the back where the old road draft tube went, blocked off with a plate, and still had the boss in the right front where the old oil fill tube used to go- undrilled. CJ manifold was the next evolution. The PI manifold is also much taller than the plain-Jane "S" intake, as is the CJ manifold- in fact the PI, CJ, F427, and the Performer RPM are all very similar in outward appearance
Nope, again, the CJ manifold has the 1.93 port- the mismatch with the heads is very old news and has been discussed many times on many forums-"The mismatch did not hurt anything with the high port dumping into the old-style long port of the CJ- Low Riser type head, as smaller went into larger, and the bottom of the "long" port is dead air anyway- CJ's came that way from the factory"
Never said they were- the CJ is the same basic design, slightly improved and generally consided to be worth another 10-15 hp over the PI- but heavy as hell in iron
Reading comprehension seems to have fallen off a bit
I happen to have 3 CJ engines, an SCJ engine, plus an extra set of CJ heads, out in the shop right now- and they all measure the same, like they always have- and 4 sets of 406 heads (long port), some C4 low risers (long port), 3 sets of Edelbrocks (short port), and lots of long-port C1AE and C4AE 390 heads, later short-port C8 and D2 heads, 3 Streetmasters (short), 3 Street Dominators (short), 3 Galaxie and 1 T-Bird 3-deuce setups (long), 2 MR 2x4 setups (short), a NOS Tunnel Wedge 2x4 (short), a PSE adapter/ Cleveland 2x4 tunnel ram setup, an F427 (long), a Port-O-Sonic (short), and probably a quarter ton of iron intakes of many varieties and vintages- and my calipers work pretty good. Running kinda short on 427's right now, only got 9
And that "S" manifold was, is, and always will be one to put on the engine if you just don't have anything else laying around, you don't want the oil to leak out the top, and you get it real cheap
Old Apr 4, 2010 | 08:34 PM
YoungMT Hick
ok so numbers to numbers this intake is going to work?????
and does anyone have any good ideas on preperation ideas for the install. i mean i got a 40 yr old intake has plenty of rust and was wondring on what is some good tips on what to do prior to install i am going to do some rust removal and try to tap out some holes but does anyone have all the bolt hole sizes????
Old Apr 5, 2010 | 09:39 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
One thing, do NOT glass-bead (sandblast) the intake ports. Or if you do, be prepared to use plenty of hot soapy water and a bottle brush to make sure you get all the sand/media out of the ports.
Many a motor has been destroyed because someone went nuts with the glass-beader and blasted the inside of an oil pan, intake, valve covers, you name it
Old Apr 5, 2010 | 12:24 PM
73 ford guy's Avatar
73 ford guy
That sucks!
dylansf23
18
Nov 8, 2014 07:35 PM
AK FORD GUY
Oct 13, 2011 11:33 AM
YoungMT Hick
Aug 21, 2011 05:44 PM
CaseynWall
Mar 10, 2009 07:56 PM
jkrussell
Aug 1, 2006 05:24 PM
