arggh
Old Mar 22, 2010 | 07:26 AM
srqdiesel chef's Avatar
srqdiesel chef
arggh
so I think I got the oil cooler fixed but I can't really tell since I CAN'T get the walrus started. I've charged the batts, and when I turn the key the gp controller just ticks and won't stop. I'm going to check the plugs when I get home today, anybody have any other ideas/suggestions.
Old Mar 22, 2010 | 08:58 AM
PLC7.3's Avatar
PLC7.3
Certainly sounds like the GPs are burned up...........what brand are they.
Only use Beru Motorcraft ZD9 in the 7.3....... get them online or at Rock Auto or a supporting Ford dealer about $10 each..
Old Mar 22, 2010 | 08:59 AM
starmilt's Avatar
starmilt
Check your controller grounds and all connections for corrosion. It works by reading the plug resistance and it doesn't take a lot of wire resistance to make it act weird.
Old Mar 23, 2010 | 04:25 PM
srqdiesel chef
checked the plugs, the controller, the fuel system(filter, schrader valve, ip) and cannot figure it out. It isn't ticking like a mad bomber any more, but just turns over and doesn't fire up. could it be a bad solenoid on top of the starter?I know that solenoid is loose but I don't know if that will keep it from starting. I just don't know enough to figure it out.
Old Mar 23, 2010 | 04:35 PM
johnboggs21's Avatar
johnboggs21
take a phillips screwdriver and tighten up that solenoid. Its definitly not helping things
Old Mar 23, 2010 | 05:15 PM
starmilt's Avatar
starmilt
The starter solenoid will not keep it from starting except for if it is loose the motor usually will not spin fast enough.
Old Mar 23, 2010 | 06:59 PM
srqdiesel chef
sorry, I wasn't clear,the solenoid itself isn't loose, the plastic thingy where all the connections are is kinda wiggly(that's tech talk) and when I crank it, it doesn't spin fast enough to start. If it's not that then what else should I be looking at?
Old Mar 23, 2010 | 07:13 PM
jmmartin's Avatar
jmmartin
Check the voltage on the batts, and when cranking, corroded connectors, dirty inside of battery connections, ummm...
Old Mar 23, 2010 | 07:16 PM
johnboggs21
might wanna clean the grounds where they connect to the block
take some sandpaper and shine em right up
I did it on mine and it seemed to help some.
Old Mar 23, 2010 | 07:27 PM
srqdiesel chef
sorry, again, shoulda mentioned 2 new batts, new + batt cable and checked and cleaned all connections shiny as a baby's a**
Old Mar 23, 2010 | 07:39 PM
johnboggs21
how many CCAs are the new batteries?
Old Mar 23, 2010 | 07:42 PM
srqdiesel chef
880 cca each.
Old Mar 23, 2010 | 07:46 PM
starmilt's Avatar
starmilt
Duh if the plastic thingy is loose, it will likely never turn over fast enough to start.
Old Mar 23, 2010 | 07:48 PM
srqdiesel chef
ya thought so, guess I'll get a new one, poop! well gotta go, have to be at work in 6 1/2 hours
Old Mar 24, 2010 | 12:29 AM
rupejosh's Avatar
rupejosh
hey easy on the technical talk your confusing me.lol
