Sponsored by: Real Truck
Question on C load tires !
Old Mar 22, 2010 | 03:14 AM
KEEPER01's Avatar
KEEPER01
HI GUYS !
Forgive my ignorance, but could somebody please explain this to me.
I bought a 02 f250 superduty for 1 thing, to pull my 3000lb boat and trailer to the lake approx. 2-3 times a month.
So here's the question !
With a truck gross weight of approx. 7000 lbs, and a tongue weight of less than 500, ( i have no idea on tongue weight,but im sure its less than 500) why cant i use C load tires that have a combined load limit of 9,880 lbs?
any opinions welcome!
thanks a bunch!
Old Mar 22, 2010 | 05:54 AM
sjgordo's Avatar
sjgordo
I would spend the extra $ and buy E Rated tires. When you add the truck weight, people, luggage, ETC the weight adds up plus towing. I bought my truck which is just shy of 10,000lb with a fifth wheel and the last owner had D Rated tires, so I replaced with E Rated. With the E rated you get thicker sidewalls and higher weight rating. It’s not worth skimping on tires to load a heavy truck with people and towing. You will be putting yourself as well other drivers on the road in danger if your heavier then your tires are rated for. I have operated plow trucks with sanders bouncing around and tire almost pealing off turning with less rated tires and it’s scary. Just my 2 cents!
Old Mar 22, 2010 | 08:05 AM
senix's Avatar
senix
C load is basically passenger car tires, not recommended for a truck. Especially when you start added a couple of items in the bed.
Be safe and get the right tire for the job.
Old Mar 22, 2010 | 08:55 AM
Furian's Avatar
Furian
You Keep What You Kill
I concur with the other FTE members... what's your life worth?
Old Mar 22, 2010 | 11:02 AM
asok's Avatar
asok
The price difference between C and E rated tires (or at least D rated) tires tends to be minimal.
I would also weigh the truck ready to roll for a fishing trip full of fuel, beer, gear, and people. You might be surprised how much weight is added.
Also, C rated tires might get a bit squishy under load.
Old Mar 22, 2010 | 12:48 PM
99powerstrokedF250's Avatar
99powerstrokedF250
Load range C tires are typically reserved for smaller SUV's and pickups, though some are available on half-ton trucks. For general driving around and maybe a few sheets of plywood, this would be acceptable. However, I would NEVER recommend them on any truck that is going to be seeing heavy or large loads.
Old Mar 22, 2010 | 02:49 PM
dkf's Avatar
dkf
The sidewalls of a C rated tire will make the SD feel mushy. Not worth it just to save little if any money on tires. If you want to save money buy a cheaper priced tire, like the Yokohama Geolander A/T-S in E rated if you can, but D will work fine too.
Old Mar 22, 2010 | 03:05 PM
seminaryranger's Avatar
seminaryranger
Will your tire shop even mount a load range "C" tire on a Super Duty pickup?
Some tire shopes will not do that sort of thing because of liability concerns.
You and I both know you'll probably be just fine and never have a blow out or anything dramatic happen like that if you use "C" rated tires. You're right, if you're just going to drive the truck around town, tow a smal boat a few miles, or pick up a few bags of potting soil from the home improvement store, they'll be fine. You gotta gauge if you want to nueter your truck's payload capacity by putting those tires on there.
Old Mar 22, 2010 | 07:04 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Yeah, you're technically "in the range" of the tire, but the sidewall flex will cause the tires to heat up a lot worse than one with more belts, and heat is what kills tires. I'd say 10K in tread life tops, if only because the treads are roasting off just with the weight of the truck
Old Mar 22, 2010 | 07:26 PM
bubbasz1's Avatar
bubbasz1
Just as DKF said, your truck will handle and ride like a 1970 Lincoln Mark 5. Don't be surprised if you get weird steering dynamics and suspension bounce. The suspension on the truck will actually cause the tire to work like a spring and the suspension it self won't do anything. They tried this at work on a dodge pickup, it was a death trap until they put the proper tires back on.
Old Mar 22, 2010 | 10:55 PM
2002 F350V10's Avatar
2002 F350V10
Ill just comment and say its not really your best choice, as a C tire would be very much inferior and prone to fail under load, such as when towing. The much weaker and more flexible sidewalls could also become a problem rather quickly. I personally would err on the side of safety.
Old Mar 23, 2010 | 12:25 AM
redford's Avatar
redford
FTE Leadership Emeritus
I think you may be overloaded even without the boat.
A typical Load Range C or 6 ply tire is rated at around 1800 pounds. Your truck probably tips the scale at 7000 and change. Guessing your weight balance at 60/40 (pickups tend to be nose heavy) that means each front tire is supporting 30% of your weight, or at least 2100 pounds.
Truck weight, tire load rating and balance will vary in each situation, but using general measurements I would not drive the truck like it is.
BPCheeta
All Things Towing
Jun 9, 2017 12:59 PM
Torklift Sheryl
Vendor Specials, Discounts, Product Announcements & Group Buys
Feb 17, 2017 01:08 PM
milkweed.gardener
Feb 17, 2017 09:38 AM
michaeloac
2009 - 2014 F150
13
Feb 21, 2012 01:00 PM
maevans
All Things Towing
Jun 12, 2007 07:16 PM
