Gear ratio questions
Type: Gear-driven, cast-iron
Low-range ratio: 1.98:1
Weight (lb.): 138
Lubricant: 80- to 90-weight
Length (in.): 13.0 (GM); 16.0 (IH)
Width (in.): 18.0
Height (in.): 12.0
Used by: 1971-1980 Broncos, Blazers, and Ramchargers (and corresponding full-size pickups); the NP 205 is still used on heavy Dodges. Some Dodge and IH models were longer, "divorce-mounted'' versions. The NP 205 has left- or right-side front outputs and a center rear output. Caution is advised: there were many varieties in NP 205 shaft splines and so forth. A PTO plate can be found on the left side of the 'case.
NP 208
Type: Chain-driven, aluminum
Low-range ratio: 2.61:1
Weight (lb): 79
Lubricant: ATF
Length (in): 8.0 (GM); 15.5 (AMC)
Width (in.): 20.0
Height (in.): 5.0
Used by: Many full-size vehicles, including Jeep pickups and Wagoneers (which used a left-side front output shaft). A part-time unit that replaced the stronger, heavier NP 203, the NP 208 can't stand up to the horsepower that the NP 205 can, but failure is more often related to low oil level than too much input torque. The 'case utilized left- or right-side front output shafts. All Jeep model 208s have the same spline and output-shaft size and bolt pattern as the Dana 300.
The c6 is 1 to 1 in high gear
