Sponsored by: Kumho
new gear
Old Jan 24, 2003 | 06:52 PM
toddnga2002's Avatar
toddnga2002
new gear
I am currently lifting my truck with a 6" susp, and going to be running 36x14.50 PJ's. Do you guys think i should worry about a lower gear or just keep it the same.
Old Jan 24, 2003 | 07:27 PM
DCSpecial's Avatar
DCSpecial
new gear
A lot of guys with the PSD run up to 38" tires with the stock 3.73 gears. You will lose some performance and your EGTs will be a little higher.
I like to regear to try and keep close to the same effective gear ratio as stock.
If you choose to regear, I'd go with 4.30 gears for the 36" tires.
Hope this helps.
