93' ford help
Old Mar 21, 2010 | 03:25 PM
Dustinlb's Avatar
Dustinlb
93' ford help
I have a 93 f150 4x4 and automatic lockouts and i was wondering how to get the brake rotors off
Old Mar 21, 2010 | 06:19 PM
fordman1090's Avatar
fordman1090
have you already taken the hubs off?
If not, i dont know the procedure for removing the autos, however i think that one you take the cover off there is a snap ring around the vary outside that is removed then the whole assembly comes out. Then remove the big spindle nut. Then the hub comes off.
to remove the rotor from the hub, take a lug nut( i suggest buying an extra one for this) put it one each stud upside down and hammer the wheel studs out. To pull them back in, hammer the stud in a little then place a upside down lug nut on it, and use a lug wrench or impact socket to pull the stud through.
