caliper brackets
Old Mar 20, 2010 | 04:55 PM
broncorckcrwlr's Avatar
broncorckcrwlr
caliper brackets
I've got a front dana 60 out of a 79 F350 I want to put under the front of my 66 bronco but it's missing the drivers' side caliper bracket. Will any later year brackets work or am I looking for a needle in a haystack?
Old Mar 20, 2010 | 10:04 PM
HillbillyDeluxe81's Avatar
HillbillyDeluxe81
It does not have to come from a 60. One from a 76-79 8 lug Dana 44 will also work. 85-91 Dana 60's use the same spindle, hub and rotor.....but not the caliper. You may be able to retro-fit 85-91 style calipers and brackets.
Old Mar 21, 2010 | 02:17 AM
CraigOutdoors's Avatar
CraigOutdoors
I was workin' on mine tonight, and it looks like I'm gonna need a right side bracket myself. The one that was on my truck is super rusted, and the one that was on the spare front end they goofed up the spring retaining bolt hole. It goes in at a really goofy angle. Looks like they fubar'd the original threads and drilled and tapped a new hole that is all askew. Anyway, if you're lookin' for a left side, and don't mind the spring retaining screw hole being stripped out, then I got one you can have.
Old Mar 21, 2010 | 07:59 AM
broncorckcrwlr
Ahh. Thanks. That at least gives me more options to look for.
Old Mar 21, 2010 | 08:06 AM
broncorckcrwlr
Are you talking about a backing plate or a caliper bracket?
Old Mar 22, 2010 | 01:25 AM
HillbillyDeluxe81
Sounds like he's talking about the caliper bracket. The stripped bolt hole is a common problem. Easily fixed with a heli-coil.
Old Mar 22, 2010 | 09:49 AM
broncorckcrwlr
Yeah, I had a brain fart. lol
Old Mar 22, 2010 | 09:52 AM
broncorckcrwlr
I'll take it. Pm me with details.
