Leveled!!!...??? (Pics)
Old Mar 27, 2010 | 08:20 PM
big poppa's Avatar
big poppa
Originally Posted by 4inchlovin
Thanks Mike...
Im going to try and hit the local salvage yards for some rear blocks...
Hope you find them, its tough finding anything truck related in our scrap yards around here, good luck.
Old Aug 16, 2010 | 05:08 PM
4inchlovin's Avatar
4inchlovin
Well havnt found any... Dose anyone have the part # for the rear blocks and or a part # for something after market that will work.
Thanks
Old Aug 16, 2010 | 05:55 PM
F350-6's Avatar
F350-6
What size are you looking for Nolan? Top Gun Custom or 4wheelparts both sell blocks and u-bolt kits in either 3" or 4". Seems like they're around $80.
Old Aug 16, 2010 | 06:33 PM
4inchlovin's Avatar
4inchlovin
Thats part of what Im confused on... The stock f250 block is 2" right??? So in which case an aftermarket 3" block should bring it level right? Or should I go 4"?
Old Aug 16, 2010 | 06:46 PM
F350-6's Avatar
F350-6
The stock block is 2". You've already got your front done, park on level ground and measure from the ground to the bumper or frame at each corner. Then determine how much you want to bring it up.
Seems like Brandon used the 4" superlift blocks from 4wheel parts on his truck.
Old Aug 16, 2010 | 07:45 PM
Stewart_H's Avatar
Stewart_H
You can always use a stock 4" block too, or even the 3.5" tapered block us Excursion owners go to when we do the V code/B code mod.
You know Ed's mantra, "OEM BABY!"
Stewart
Old Aug 16, 2010 | 07:47 PM
megawatt00's Avatar
megawatt00
I need to measure my truck, after my leveling kit I am a bit nose high now too........
Old Aug 16, 2010 | 09:38 PM
4inchlovin's Avatar
4inchlovin
dude that would defeat the purpose of asking yall... I didnt want to have to do any work...
Old Aug 16, 2010 | 11:15 PM
BDalton's Avatar
BDalton
This thread might help:
https://www.ford-trucks.com/forums/6...ar-blocks.html
Old Aug 17, 2010 | 07:27 AM
mechelement's Avatar
mechelement
Put a loaded trailer on the back and post pics of how level it is.
Old Aug 17, 2010 | 07:58 AM
bama29fan's Avatar
bama29fan
not meaning to change the subject but what happened with the ranch hand bumper you had
Old Aug 17, 2010 | 08:02 AM
spdmpo's Avatar
spdmpo
One of these days i will get my air bags installed in the rear to help with sag while towing. But the f350 blocks in the rear would make it sit nice i think.
Just a suggestion because in my case after I added air bags it made the rear end sit high again. You have to always a keep 5-10psi in the bags and that will raise the back when empty. I ended up swapping Mike for his 250 blocks and now mine sits perfect and we are both happy. You might want to consider leaving it until you do the bags and then see if you still want the taller blocks, or you might be doing it again.
Old Aug 17, 2010 | 11:18 AM
  #28
Stewart_H's Avatar
Stewart_H
The pictures are old, from before he put the bumper on.
Stewart
Old Aug 17, 2010 | 11:45 AM
  #29
bama29fan's Avatar
bama29fan
Stewart
gotya!!! i was thinking the lift was recent.
Old Aug 17, 2010 | 01:08 PM
  #30
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
Stewart
Thats right baby!
