Replacing fuel lines
Old Mar 20, 2010 | 02:33 PM
hayisforhorses's Avatar
hayisforhorses
Having hard starts for first start of the day all new berus and new solid state controller. Once it is started and runs rough for 10-15 sec it is ok. You can shut it off and start again with no problems. Return lines for the injectors are all dry, the main fuel line has been hacked and spliced to run on 1 tank due to a faulty fuel switching valve. I got the part # for fuel line replacement from mcmaster carr only how do you do the connections to the fuel senders, they don't have the locking ends just hose? asny suggestions?
Old Mar 20, 2010 | 07:12 PM
starmilt's Avatar
starmilt
Are these the ends you are talking about that are missing. If so, as far as I know they will be a dealer only item.
Old Mar 20, 2010 | 09:31 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
local auto zone had some behind the counter when i asked for them just in case back along.
our fuel system is all low pressure,so you can just slip on fuel hose and clamp it if ya want.
i dont even know why i bothered to keep mine,but i did.
