94 F150 e4od problems
Old Mar 19, 2010 | 03:24 PM
lestro's Avatar
lestro
My 4x4 transmission was grinding in neutral, so I replaced it with a "good" used one. The old one ran and shifted fine. I put in the good one, drained all the fluid (it looked fine) and replaced the filter. Now I only have reverse, 1 and 2. I had a mlps code so I put my old mlps switch on and cleared the codes. Now I have no codes, but still no 3-4 gears.Think if I put my old valve body and solenoid pack in that it would solve this?
Old Mar 19, 2010 | 03:29 PM
DRRXR's Avatar
DRRXR
Are you sure you aligned your mlps to the right external marking?
Old Mar 19, 2010 | 04:59 PM
lestro's Avatar
lestro
reasonably sure, I put it in neutral and lined up the small line with the neutral line. I'm not getting the code now after I test drove it.thanks
