Tapping noise from tranny
Old Mar 18, 2010 | 11:20 PM
RobbyMartin's Avatar
RobbyMartin
I have an '02 F150 Screw that had a 4.6 and I swapped it to an '03 5.4. Ever since the install my tranny has been making a tapping noise when I put it in gear and even sometimes when I rev it up in park. Any ideas what it could be? ..
The tranny is a 4r70w and the engine is from the Windsor plant.
Old Mar 18, 2010 | 11:55 PM
stuart1's Avatar
stuart1
tapping noise
Is it sending morse code by any chance?
It could be the convertor bolts hitting the cover or a cracked flex plate.
Old Mar 19, 2010 | 08:53 AM
RobbyMartin
As a matter of fact, it is sending morse code. It's saying, "Get this fixed, stupid."
How do I check these bolts? I know very little about transmissions.
Old Mar 19, 2010 | 10:09 AM
stuart1's Avatar
stuart1
There's an inspection cover in front of the transmission that can be removed so you should be able to have a looksee.
There may be evidence of bolts rubbing against the cover.
Old Mar 19, 2010 | 02:08 PM
RobbyMartin
I removed the inspection plate on the tranny and a round grommet on the block and couldn't see any obvious damage to the flexplate and I couldn't see any bolts to inspect for tightness. Did I check all the right places for loose bolts?
